Hey everyone,
I have a 2wd 95 3.0 ext cab and the front end sags. The springs were replaced in Oct 01 and the shocks are procomps and installed in April 04. I would like to atleast get the front level with the rear. Would new 2" lift springs and shocks do the trick? What concerns should I have with changing the springs? I'm eventually going to get a lift kit, when I get the money to do it. I'm just looking to get rid of the sag for now.
You could get 2" spring spacers, but the 2" lift springs are better, with only 2" of lift there should be no real concerns. You won't need a dropped pitman arm or anything. Longer shocks are optional, but you are gonna get them anyway. That should just about level your truck out, good luck, hope it works out for you.
