Oil & Lubrication
Variable oil useage
Old Sep 28, 2006 | 06:26 PM
Avanti's Avatar
Avanti
Variable oil useage
My 89 BII with 50K on a rebuilt engine uses oil at different rates under the same driving conditions. It leaks very little. Some time it will suck a quart in 400 miles and another time a quart in a thousand miles. It has done this off and on for a couple of years. Any ideas??? PVC?? I like the BII, just would like to figure this one out. Worked on cars for years.
Old Sep 29, 2006 | 12:18 PM
pawpaw's Avatar
pawpaw
Might be helpful to know which engine.
I too was thinking a acting out/sticking PCV valve, when last was it replaced????
Or maybe sticking ring/s!!!!
Did you changed oil weight or brands, when this began????
Old Sep 30, 2006 | 07:26 AM
Avanti's Avatar
Avanti
oil useage
Been using the same oil in the 2.9 Bronco engine for the last two years. Changed the PVC. & see what happens. I did change it a year ago.
Old Sep 30, 2006 | 07:43 AM
pawpaw's Avatar
pawpaw
Well if the PCV was only a year old I doubt it was fouled up, unless it failed mechanically some how & stuck shut.
Did the oil useage come about slowly over time, or suddenly, after some event, like a service, repair, trip, unusual drive cycle, ect, ect????
Old Sep 30, 2006 | 04:53 PM
Avanti's Avatar
Avanti
It comes & goes. It was all of the sudden. I do all my own work & have since 1998.Worn rings would be a constant loss with smoke.It would not get better. The same way with a leak.
Old Oct 1, 2006 | 07:47 AM
pawpaw's Avatar
pawpaw
I wasn't thinking worn rings, just intermittently "sticking" rings, from deposts on the piston ring lands.
But from your description of it leaking some oil & sometimes going on a drinking fit, your idea of a acting out & maybe intermittently sticking PCV valve is a good one too.
Did the problem begin just after you last replaced the PCV valve?????? If so then maybe it was defective!!!!!!
Have the pistons ever been out???? If so, then maybe the ring gaps weren't aligned properly on one or more pistons, before installation.
Are you using the specified weight crankcase lube????
Did you change anything or do anything different, prior to this begining, like changing the weight or grade of oil????
Old Oct 1, 2006 | 04:19 PM
Avanti's Avatar
Avanti
I changed the PVC last spring. Been using 10W30 all the time. Will make another oil check next week.
yyyames
Bronco II
Jul 31, 2012 09:53 PM
BII Plow Truck
Bronco II
Apr 17, 2009 10:12 AM
climber87
Bronco II
Jul 12, 2008 10:09 AM
SShank42
Bronco II
Mar 11, 2006 07:25 AM
threespeed
Bronco II
Aug 1, 2005 11:43 AM
