How do you remove...
Old Sep 28, 2006 | 03:42 PM
apollo95's Avatar
apollo95
The white blower motor wheel from the actual blower motor? I am going to pick up a replacement one today for my '95 4cyl (a Seimens brand). The replacement motor doesn't come with the wheel. For the life of me, I can't figure out how to remove it! My Haynes manual doesn't tell me either.
Thanks.
Dave
Old Sep 28, 2006 | 04:52 PM
fyre82's Avatar
fyre82
Is there a set screw on the side, or one in the end of the motor shaft?
It may be a friction fit and pull off. My ranger is older and I believe it had a friction fit fan.
Good luck.
Rich
Old Sep 28, 2006 | 05:31 PM
wendell borror's Avatar
wendell borror
I believe they pull off, it's very very hard and easy to break as they are plastic. I tried it once on an 84 and broke it, I then gave up. Took the new motor back, and then took the ranger to the shop. 250.00$ later, it was working. They seem to be pressed on some how, good luck as you will need it.
Old Sep 28, 2006 | 07:53 PM
apollo95's Avatar
apollo95
No set screw that I see.....
Old Sep 28, 2006 | 07:59 PM
COUGARFIED's Avatar
COUGARFIED
Try heating the center of the wheel with a heat gun or a hair dryer. then wiggle it back and forth, i believe it is a compression fit.
Old Sep 29, 2006 | 08:31 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
If all else fails o'reileys sells the plastic blower wheel also. If I remember correctly it was under $10.00
Old Sep 29, 2006 | 10:08 AM
apollo95's Avatar
apollo95
I am picking it up after work today and installing it tonight. Stay tuned!
Dave
