EGR Question.
Old Sep 29, 2006 | 09:37 AM
CanadaGuy's Avatar
CanadaGuy
It's not that much of an inconvenience to use a fuel additive each fill up, especially if you plan to keep the truck for many years. Why take the risk of having a fuel injector failure after the warranty runs out when you can use an additive to increase lubricity and (hopefully) increase the life of your injectors.
Old Sep 29, 2006 | 09:59 AM
walleye's Avatar
walleye
I have an 03 6.0 w/120000 miles and was having EGR problems at 80000.
After disconnecting it 40000 miles ago I have had no problems at all , I still get high idle when cold and my oil is still clean at 5000 mile which never happened before.
Old Sep 29, 2006 | 01:02 PM
heavyiron's Avatar
heavyiron
The reason (mine) for the EGR knock off is this (and if theres a chance it is still open, then its going to be "modified" so that it is definately shut)
We pay quite alot for air filters, quality oil, fuel additives etc etc and then, we let a % of exhaust gas back into the intake manifold? Burnt diesel. I know why they do it, but it makes no sense from a life expectancy stand point.
Maybe it does no harm, maybe it doesnt contaminate the oil, maybe, maybe.
Heck, why should I care, I have a 5 yr, 100k warranty. The reason is I absolutely loathe anytime my truck has to go in for service (my last one had a persistant pinging problem, and rather than try and fix it, I sold it) I loathe service departments. Sooooo, if I can help my engine stay clean and healthy, I'm sure going to try
Old Sep 29, 2006 | 01:20 PM
LVEILLON's Avatar
LVEILLON
Originally Posted by kw5413
Don't know if this means anything or not but, my EGR Valve was "knocked out " over 30,000 miles ago....and it still high idles when it was designed to.
To LVEILLON's question:
"Again...What are ya'll wanting to achieve by disconnecting the EGR?"
Zero shop time and longevity.
My EGR Valve was disabled immediately after being replaced when I got my last re-flash about 14 months ago. Therefore, I am extremely confident that it is closed.
Keep in mind that I have only advocated the disabling of the W. A. R. T. on '03 / '04 6.0 engine builds.
FYI: My truck never blows smoke...at any time. Clean as a whistle....But, I also use PowerService @ each and every fuel up.
Thanks KW5413...That answers my question. I know from time to time there are guys out there that may be thinking they are getting something from a modification that they don't ever see happen. I have my EGR turned off with my SCT tuner.
I think using a fuel additive is just as important as buying fuel from a quality station. I'm curious to see the setup on the new 6.4's when they hit the street.
Old Sep 29, 2006 | 01:23 PM
LVEILLON's Avatar
LVEILLON
Heavyiron...are you saying that you have your EGR Blocked off physically or you just unplugged the EGR. Maybe I misunderstood.
Old Oct 3, 2006 | 01:00 AM
Cowboy Brett's Avatar
Cowboy Brett
Originally Posted by LVEILLON
Brett...Actually the HighIdle keeps the EGR opened and operational as if you were at normal driving speeds.
From what several of the FORD techs in the forum have reported is that crappy cheap fuel is a main problem and too much idling. The HighIdle mod greatly helps this. Also use of a fuel additive is best.
Thanks for the info. Like I said, no problems here yet.
ben158
Feb 24, 2015 11:40 AM
ben158
Feb 23, 2015 06:13 AM
tlc3810
Apr 18, 2013 04:22 PM
paintballpro650
Mar 18, 2011 06:03 PM
2006explorer2006
Feb 8, 2008 01:13 AM
