Sponsored by: Real Truck
hubs sqeaking
Old Sep 26, 2006 | 04:31 PM
Adam/'s Avatar
Adam/
hubs sqeaking
My 2000 SD pickup with manual hubs will emit a high pitch sqeaking noise from the front end when the hubs are locked in only. It changes with the speed of the vehicle. Slightly decreasing after driving 30 + minutes. Have jacked up the front but been unable to dupicate it. Any thoughts?
Old Sep 26, 2006 | 06:49 PM
FortyFords's Avatar
FortyFords
Adam ,your hubs need to be taken apart and inspected for worn parts.Then cleaned cleaned and grease the small needle bearings that support your axle shafts.
Don't drive too long with this condition or you will cost yourself more $
Rich
Old Sep 27, 2006 | 10:22 AM
harald's Avatar
harald
My 2000 did this while under warranty and they replaced the dust seals. Apparantly you need to engage 4x4 at least once a month to keep things lubed or else you'll end up with this problem.
Old Sep 27, 2006 | 10:36 AM
Adam/'s Avatar
Adam/
Thanks for the replies, I have to deal with the ball joint replacments so I will add to my to do list while its apart.
Old Sep 27, 2006 | 10:09 PM
RACERX7775's Avatar
RACERX7775
this is the time... i just had to replace my r/f hub bearing assembly today. it was making the loud ratcheting noise. when i took the hub off, i noticed that the axle had alot of up/down movement at the axle housing end. i am not sure if this is normal.no leaks though. it is making the quits eeeeeekkkk when i turn the axle by hand. it is coming from the seal at the end of the axle housing....
