Engine Mounts
Old Jan 31, 2001 | 07:13 PM
63unibody's Avatar
63unibody
Engine Mounts
I was wondering if a 292 would fit in a 65 frame?
63 Unibody
Old Jan 31, 2001 | 10:44 PM
Nate_64's Avatar
Nate_64
Engine Mounts
Nope- not without a bunch of work anyway.
Nate
1964 F-100 Custom Cab 292 V-8 3 spd
1964 F-100 292 V-8 3 spd
1990 F-150 5.8L
Check out http://clubs.yahoo.com/clubs/fordpickups61to66fseries
Old Feb 1, 2001 | 01:03 AM
hpguy's Avatar
hpguy
Engine Mounts
A lot of the 292's used a single engine mount in the front, that went around the front of the block, and bolted to the front of the frame. If you could build your own mount like this, or if you could create your own crossmember to bolt the front-mount to it shouldn't be too bad... just the tranny, and possible driveshaft adjustments. I'll see if I can't get a pic of the engine mount that I'm talking about tomorrow sometime.
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
Old Feb 1, 2001 | 04:32 PM
63unibody's Avatar
63unibody
Engine Mounts
What if I took the mounts out of the 63 frame and mounted in in?
63 Unibody
Old Feb 1, 2001 | 06:20 PM
hpguy's Avatar
hpguy
Engine Mounts
You might have to make a custom crossmember, but it's do-able.
Have you visited the Y-block forum?
-Andrew
Old Feb 5, 2001 | 12:01 AM
abeln's Avatar
abeln
Engine Mounts
I would have to own a might fine 292 to make it worth my time!
Old Feb 5, 2001 | 12:14 AM
hpguy's Avatar
hpguy
Engine Mounts
I'd like you to know that I'm personally offended by that.
What, may I ask?, is wrong with a 292? Have you ever driven one that was taken care of?
-Andrew
Old Feb 5, 2001 | 01:48 PM
skip4274's Avatar
skip4274
Engine Mounts
mrcman58
1961 - 1963 F100 Unibody
Nov 20, 2015 06:04 PM
svolpone
Aug 24, 2015 01:51 PM
hewer_07
13
Aug 28, 2008 01:47 AM
frigerator
Mar 21, 2007 06:25 AM
Comer14
Mar 4, 2003 09:36 AM
