I 've been looking for where the harness plugs in. I can't find an empty plug anywhere. I think it should plug in behind the passager kick panel. I took the kick panel off and there is no empty plug there. Any suggestions would be greatly appreciated!!
I bought the same kit for my 2001 and the plug was taped up to the main harness on the passenger side kick, not sure if that is where its at on a 2006, but that is where it is on a 2001
do you have the over head console? that may make a difference as I think (Im not totaly sure) there may be a different harness that interfaces with the overhead as thay may plug in the same spot.
