Sponsored by: Real Truck
Door ajar light
Old Sep 25, 2006 | 03:15 PM
DanE.'s Avatar
DanE.
Door ajar light
Hi all, I Just had my truck rust proofed and now the door ajar & dome light are on. Of coarse the guys at the shop said thats the way it was when i brought it in. I looked around for the door switches but could not fine them. This is and extened cab. there apears to be a switch on the haft doors? I'm not sure if it is it or not. Could I get some guildance on what to look for? Thanks Dan...
Old Sep 25, 2006 | 03:20 PM
HD1340's Avatar
HD1340
The switch is in the door latch. Try spraying WD40 right into the latch and open and close the door a few times. That usually frees up the switch. If not you will need to remove the door panel to gain access to the switch.
Old Sep 25, 2006 | 06:39 PM
DanE.'s Avatar
DanE.
Thanks, That worked. DanE.
