1978 - 1996 Big Bronco
Tail light question 87 Bronco
Old Sep 24, 2006 | 09:28 PM
v8xploder's Avatar
v8xploder
I just picked up a beater truck to drive back and forth to work in, I noticed that neither of the drivers side tail light/brake light work. Are they on a seperate ground system than the pass. side rear tail lights? They work fine. I replaced the bulbs and still nothing. I checked underneith for a seperate ground didnt see much. Anyone had this problem or know the cure??
Old Sep 25, 2006 | 12:01 AM
greystreak92's Avatar
greystreak92
The ground location is behind the lens assembly if I recall. The ground is common to both sides via the harness on the newer models but I'm not sure about the 80's vintage.
Old Sep 25, 2006 | 11:22 PM
dwoodler's Avatar
dwoodler
Check for power at the light with a test light. Then you can see if it is the ground or power. I'm pretty sure the power wire to the pass. side splits before the bulb connection.
Old Sep 26, 2006 | 11:02 PM
v8xploder's Avatar
v8xploder
Turns out the previous owner had installed a "new" tail light bulb. They had put an single element bulb in the Brake/Tail light Dual filiment socket.
Old Sep 27, 2006 | 03:55 PM
dwoodler's Avatar
dwoodler
That's my kind of repair job!! (the one you did not the p/o!)
abe
Sep 27, 2012 08:50 PM
henry80
Mar 17, 2010 07:28 PM
hp246
Jun 21, 2009 02:06 PM
73f100shorty
Electrical Systems/Wiring
Jun 7, 2007 07:24 AM
BetsyBlue79F150Custom
Jul 25, 2002 05:28 PM
