Instrument cluster
Old Sep 24, 2006 | 07:21 PM
Ranger_Chuck's Avatar
Ranger_Chuck
Instrument cluster
Hi guys, I have a 96 Ranger 2WD 3.0, the temp, oil pressure, and voltage guages are all over the place. temp gage tops out, oil pressure guage goes real high, voltage gage goes real low. had the alt and batt checked (ok). truck runs just fine. fuel gage and speedo are fine. any ideas?
Old Sep 24, 2006 | 09:12 PM
Tiggie's Avatar
Tiggie
Possibly an intrument voltage regular, if these newer trucks have one.
Sounds like it may be a ground problem of some sort. Maybe the wiring harnesses are loose behind the intrument cluster?
Old Sep 25, 2006 | 07:06 PM
Ranger_Chuck
someone else told me about the inst voltage reg. i thought about a ground problem too. I havent been able to find a diagram to tell me if the truck has a regulator or not.
Old Sep 25, 2006 | 07:31 PM
Rockledge's Avatar
Rockledge
I concur. There is a common ground (BK/W wire) for all those gauges.
Unplug the middle harness connector from the instrument cluster (there are 3 back there) and you should find that ground wire at Pin #2.
There is no instrument cluster voltage regulator on the '96.
P.S Welcome to FTE!
Old Sep 25, 2006 | 07:48 PM
Ranger_Chuck
I'll definately give that a shot, I have browsed through here before and just knew someone here could give me some tips. THANKS
