tranny info
Old Sep 23, 2006 | 10:51 PM
okcwby390f's Avatar
okcwby390f
Cool tranny info
I have a 94 f350 2wd with an E40D. I am haveing a tranny problem with speratic shift in forward. Some long hesitations between shifts an times. Some times it will not shift into overdrive at times. also reverse hesitates. the clutch packs look good and are not overly loose. I had the valve body looked at and I think the check ***** are in the wrong place. I took the valve body apart and i have ten plastic check *****, one steel check ball, one needle check ball, and one spring. I need to know proper placement of these items. I would like a diagram if any one has one. Thanks.
