engine
Old Sep 23, 2006 | 09:46 PM
slavik's Avatar
slavik
engine
the guy i bought my 53 f-100 from says the motor is a 279 out of a firetruck with 3000 hours on it. is this a odd ball? i most likely won't use it.
Old Sep 23, 2006 | 10:27 PM
fking1's Avatar
fking1
There was a 279 OHV V8 in 53 that was used in P-350 Parcel Delivery Vans. The Ford Parts Catalog doesn't show Fire Trucks, but, that doesn't mean that engine wasn't used in one. The 279 definitely did not come in a F100.
Fred
Old Sep 23, 2006 | 10:44 PM
Bdox's Avatar
Bdox
Sounds like a candidate for a nice 302!
Old Sep 24, 2006 | 12:36 AM
Bessie's Avatar
Bessie
The only real way to tell is to get casting numbers off your engine. Post em here and many members will help you out.
Old Sep 24, 2006 | 09:24 AM
51dueller's Avatar
51dueller
That engine was used in the F-700 and F-800 trucks. It was also used in the Lincoln cars from that time. It's rated at 145 HP @ 3800 RPM and 244 ft.lbs @ 19-2100 RPM. If it is in good running condition, I'd keep it as it is different from the belly button bow tie engines.
