Why no reverse?
Old Sep 23, 2006 | 05:45 PM
Hereford 350's Avatar
Hereford 350
Why no reverse?
My F250 has an automatic with overdrive behind the diesel Its been sitting for 4 years drove fine before it sat now when I decide to put her on the road I have no reverse. Is there anything I can check or do before I say I need a tranny?
Old Sep 23, 2006 | 06:32 PM
trike1946's Avatar
trike1946
Try dropping the pan and change the fluid and filter. I assume you checked the fluid level. Is the shifter linkage working right? Pull the wiring plug on the passenger side and clean it and put it back.
Old Sep 23, 2006 | 07:09 PM
DNewton's Avatar
DNewton
id have to say your low on ATF, if there is any at all, that would be the first thing i check, then the linkage, but i had the same problem on my truck, its just needed a few quarts of ATF. Dustin
Old Sep 23, 2006 | 09:45 PM
Hereford 350
no reverse
I did check the tranny fluid right away and it is full. I'll chech the linkage and plug tommorrow.Thanks
Old Sep 23, 2006 | 09:50 PM
DNewton's Avatar
DNewton
ok, the other optin is if its too full, it is within the "low" and "full" boundry lines right? it will also not work right if there is too much fluid in it...
Old Sep 24, 2006 | 12:17 PM
Spectramac's Avatar
Spectramac
Are you checking it with the engine running? Sorry, had to ask.
If nothing else, I'd guess a sticky valve in the body is hanging you up. My truck had sat for a few years when I got it. I took it for a test drive around the block, came back and shut it off. An hour later it was dead, wouldn't move at all. I wasn't sure what happened, so I just replaced the tranny. I pulled the old one down, it was beautiful inside, but the valve body was full of red mud.
AB1946
Jan 15, 2012 02:15 PM
mfp4073
1983 - 2012 Ranger & B-Series
Jun 2, 2010 05:35 PM
rasta
24
Mar 31, 2007 08:44 AM
xman7896
May 21, 2004 10:50 AM
bigwheelin
Mar 18, 2004 08:49 AM
