Dumb ? about timing
Old Sep 27, 2006 | 08:00 PM
85e150's Avatar
85e150
Can you confirm if the one mark on the crank is TDC?
If so, you can:
Buy tape with the degrees on it, if you are lucky enough to find it for your damper size. Or find it at all.
Make your own mark by either sectioning off the damper and marking it yourself.
( you know, one line is 180, two perpendiculars is 90, half of that 45, half of that 22.5, half 11.25 etc)
Or make your own tape by measuring the diameter of the harmonic balancer and do the math to determine circumference and then divide by 360 for degrees or 36 for 10 degrees at a time.. (circumference = pi x diameter)
Go here for the full number for pi, as you want to get a close as you can to reduce error.
Or, you could just time it by ear. Move the dizzy until you get the best idle.
Then go out and run the hell out of it. If it pings, back it off and try again.
I found 8 degrees was the max for my 289 on the free gas my old man supplied on the farm....
Old Sep 28, 2006 | 06:18 AM
subford's Avatar
subford
Originally Posted by beaners1
My mistake on the ignition, my truck had the eec system on it the van has the duraspark systen on it. The module has the number 12A199 on it, not sure if it's the I, II, or III system. The sticker under the hood says 10 degrees at 500 rpm with the vacuum advance disconnected and plugged. I just don't know where 10 degrees is.
On the underside of the module it will have a colored insulator where the wires go in, if it is blue it is a Duraspark II, if it is a brown insulator it is a Duraspark III (EEC III).
Let us know the color, if it is some other color lets know that too but these are the most common.
Old Sep 28, 2006 | 07:24 AM
beaners1's Avatar
beaners1
Thanks alot, I'll have to check on the color code, didn't know that, I have done the measuring of the balancer on my race car and tried to set it at 34 degrees and got it to 28, not bad but not close enough in my opinion. I can't confrim that the notch is TDC thats why I asked what I thought to be a dumb guestion but it truns out that there are no dumb questions. Again thanks for all the input, I'm sure we'll get it right eventually.
Old Sep 28, 2006 | 07:32 AM
beaners1's Avatar
beaners1
Ok just checked the insulator wire is blue.
Old Sep 28, 2006 | 09:21 AM
subford's Avatar
subford
OK it is a Duraspark II system. Somebody must have worked on the engine and replaced the Vibration damper with one from a Duraspark III system and left the pointer off, it just bolts on.
One more thing, do you have a vacuum diaphragm on the distributor?
Are there any wires down around the Vibration damper?
Old Sep 28, 2006 | 12:05 PM
pfogle's Avatar
pfogle
Also if you still have the vacuum diagram on the core support it will say EECIII, or Duraspark 2, or whatever it is. It may also say CATALYST, or NON-CATALYST.
I have the DS2 system, but my grommets are yellow. I also have the cali-emissions model.
Old Sep 28, 2006 | 12:42 PM
beaners1's Avatar
beaners1
Didn't see anything about what ignition it is on the diagram but it does say catalyst, no wires by the dampner.
Old Sep 28, 2006 | 12:49 PM
subford's Avatar
subford
Do you have a vacuum diaphragm on the distributor?
Also someone may have converted this from a DP III to a DP II.
Old Sep 29, 2006 | 06:47 AM
beaners1's Avatar
beaners1
OK I cheated and found a guy with an adjustable timing light, seems to have more power, haven't driven it long enough to get it warmed up yet. Thanks for all the help, this is what makes this site so great.
