Completed the High Idle Mod today using #4 upfitter switch. It is idling at 1200 rpm. Question I have is how long of an idle is it proper to use the high idle?? I have two kids and sometimes stopping at side of road for potty breaks. If I idle for a minute , two, five , etc....
The idling sounds really high. Is this normal?? It just sounds rough on the motor.
If its sitting much more than 10 minutes, I use high idle. Less than that I dont bother. Mostly for me this is in the winter, in summer I just drive, shut off unless I have been pulling and use low idle for 5 or 10 min before shut down.
I just finshed the high idle mod on my 04 6.0 and am satisfied with the results. The sound of the engine @ 1200 RPM does seem load but I don't think it can harm anything. In the business I was in before I retired we used F350s and ran generators off a PTO for hours at a time (some times days) with the idle set at 1150 RPM with no ill effects. Granted these were 7.3 engines. The hours on these engines way over shadowed the milage.
I don't idle my 6.0 much. When I'm towing I have found that by the time I let off to exit the freeway, get onto the side road and get into the fuel station is a least a few minutes, enough to let the turbo cool down. If I'm not towing then I just shut it down and go into the store, restroom or whatever. I guess it would be different if I lived in a cold climate.
Sorry to interupt, but I have a 2007 SD and am trying to wire the same I found the upfitter wire but the access wire is nowhere to be found. I supose the 06 should be the same as the 07. Can you please point me in the right direction.
Headviking
Found it. I should listen to the wife when she tells me to put on my glasses. But I look cool without READING GLASSES. Thanks again.
Headviking (with reading glasses)
That's it . . . U Need to look cool stuff up under your dash, trying to find a tiny wire you are trying to put a BUTT connector on, with little or no room to see, move, let alone finish the job in . . .
Completed the High Idle mod yesterday, worked like a champ. I have a 06 PSD and decided to use the Solid Orange PTO wire instead of the BCP wire. Wired it to the first 10amp upfitter switch, #3. I also unplugged, removed and cleaned my EGR valve. I have about 18K on it and wanted to see what it looked like. It was about as bad as expected, not wet, but heavy carbon and black buildup.
