1999 Intake
Old Sep 22, 2006 | 09:32 PM
jbawilliams's Avatar
jbawilliams
1999 Intake
Does anybody know why they moved the intake from the drivers side fender from the early 99s to over the batter after that? Mine is an early 99. Just wondered.
Old Sep 22, 2006 | 10:38 PM
clux's Avatar
clux
They had trouble with engine dustings with the 99 airbox.
Old Sep 25, 2006 | 02:04 PM
Mark at DPPI's Avatar
Mark at DPPI
jbawilliams,
Dust was a problem as well as water ingestion in a number of engines too!
Mark @ DPPI
Old Sep 25, 2006 | 08:52 PM
jbawilliams
6637 on True 1999
Can it be done?
Old Sep 25, 2006 | 10:33 PM
John311t's Avatar
John311t
Well my understanding of the 6637 is that it just goes in place of the airbox. I also got the early 99 and im going to be ripping out my stock airbox to put the 6637 in as well.
Old Sep 26, 2006 | 04:54 PM
Ford Truck Racer's Avatar
Ford Truck Racer
I put the 6637 on my 99, It pulls a little against the relays, but not enough to worry me.
Old Sep 26, 2006 | 10:15 PM
Fat Diesel's Avatar
Fat Diesel
Here's a pic of my early 99 setup:
Old Sep 26, 2006 | 10:20 PM
John311t's Avatar
John311t
i like how you bent the pipe at the end where it goes to the airfilter.
Old Sep 27, 2006 | 10:05 AM
randle_ford's Avatar
randle_ford
Fatdiesel
Where did you get the elbow? I have an early '99 as well and I had to use a 22.5* PVC from home depot in the same place you have yours. No exhaust shop around me can bend 4" tubing.
Old Sep 27, 2006 | 12:20 PM
Fat Diesel's Avatar
Fat Diesel
I got the elbow at a big rig supply shop in San Jose on Old Bayshore Rd just east of 10th street. You wanna find a shop that is specifically for big rig parts. I had to cut it a couple of times to get the length just right. I also reversed the hose that goes from the filter to the CCV piece. The main thing is to make sure it doesn't rub on your intercooler pipe on that side. The pipe is very soft aluminum and will wear through if you give it enough time. If you look closely enough, you can see how I have the filter "shoe" horned in there. Yeah, that's an old shoe in there... The flat bottom of an old shoe combined with the moldability of the top makes for a great seat for hte filter. Also I put an empty 1 Qt oil bottle in between it and the fender area... LOW BUCK MOD! Buy your filters 2 or 3 at a time from Fleetfilter and you'll save big bucks on the filter elements. If you buy three it comes out to about $75 including the shipping.
Old Sep 27, 2006 | 03:20 PM
mattyg50's Avatar
mattyg50
what do you do with the air sensor if you remove the stock box?
Old Sep 27, 2006 | 03:26 PM
Fat Diesel's Avatar
Fat Diesel
I noticed mine dangling down near the drivers side tire. I need to get it zip tied back up to something.
Old Sep 27, 2006 | 07:58 PM
Kwikkordead's Avatar
Kwikkordead
Extend the wires about 9 inches and do this.
Old Sep 27, 2006 | 10:32 PM
mattyg50's Avatar
mattyg50
i got it all installed!!!
i used a pvc pipe at a 45 degree and it fits perfect
thanks for the info
