Bronco II Ford Bronco II
loosing coolant.
Old Sep 22, 2006 | 01:23 PM
raveng60's Avatar
raveng60
Question loosing coolant.
hi, the B is loosing coolant slowly but surelly. its not a big hassle but i just thought it be nice not to have to top off every 2 or 3 weeks.
its an '89 and it dont seem to be leaking on the floor or anywhere else.
could it be leaking from the head gasket? but then the engine runs very strong. i'm confused.
Old Sep 22, 2006 | 01:46 PM
mrshorty's Avatar
mrshorty
Slow leaks can be irritating to find, because they may be slow enough that the coolant evaporates before it can drip to the ground. I would start by getting a pressure tester (I think Autozone carries one as part of their loan-a-tool program), hook it up, and see if it shows up with the engine cold.
Old Nov 1, 2006 | 09:44 PM
plilikoi's Avatar
plilikoi
Check the heater core. See if it's discharging into the engine compartment where it runs down the front of the firewall.
Old Nov 2, 2006 | 05:17 PM
my72ford's Avatar
my72ford
check around the radiator tanks and see if there is any corrosion,that is a sign of leakage,as mentioned already check around the heater core area,and check the engine oil to see if it is discolored to a milky color,if that is the case you probably either have a blown head gasket or a cracked head. does the engine run hot? have had any overheating issues? may also want to check around the thermostat housing. i have seen some slow leaks there. hope this helps
Old Nov 3, 2006 | 06:42 AM
Eric C.'s Avatar
Eric C.
These are all the good basics and look at them. If there is nothing definitive then you'll have to go ahead and pressure test it. When my Aerostar did it I could find nothing under no pressure, but at 3 PSI it was a geyeser on the radiator tank.Make sure that before you start the pressure test that the cooling system is full to the top first.
Old Nov 3, 2006 | 03:49 PM
SShank42's Avatar
SShank42
Mine did same thing. It was an intake gasket leaking into exhuast. So small of a leak it evaporated going thru the exhaust. Eventually it got big enough to find.
Old Nov 10, 2006 | 11:14 PM
raveng60's Avatar
raveng60
yea thats what i thought...i'm willing to bet its the intake gasket.
i wont do a preasure test on this vehicle simply because i think it will do more damage than good. same with backflushing/flushing the oil system.
Old Nov 16, 2006 | 08:20 AM
HappyJack's Avatar
HappyJack
My 88 had a cracked head. Did the pressure test and couldn't find anything. Truck ran good and the compression test was great. Used about a 1/2 galon of coolant every 30 miles or so. There is a dye that you can put in the coolant to find the leek. My heads were cracked on the top of the exhaust ports up to the valve covers.
Old Nov 16, 2006 | 10:07 AM
youngfordguy's Avatar
youngfordguy
the bIIs were bad for heads cracking i bet its that or the intake
Old Nov 16, 2006 | 09:09 PM
plilikoi's Avatar
plilikoi
It could also be the water pump that's leaking.
Old Nov 21, 2006 | 04:00 PM
Phil32010's Avatar
Phil32010
I don't think a pressure test will hurt anything as long as you set it to the correct pressure. Look at your radiator cap and it will tell you the proper pressure to test it at, keep in mind the coolant system should be maintaining that same amount of pressure when running. So if its running at a certain pressure testing at that same pressure shouldn't hurt a thing!
hope This Helps
Phil
