ok first off, where would i go about buying a rebuild kit for a 93 e40d. the symptoms of my tranny are it sticks in first gear unless u let off the gas a bit, and its not the kickdown, sometimes when i go over bumps the speedo whips around and half the time my tranny downshifts when this happens. and now the eec, what hard ware do i need off moates to use eecedit?
thanks aheada time
also i fergot to include, im not sure which tranny it is, ive heard that its an aode and e4od, the tranny code on the door is E. also which axle is code 18
Your best bet is to go to a tranny shop and buy a kit. They will know exactly what you need. I agree that you should check your speed sensor first. They tend to cause alot of problems.
'93? You need the moates.net j3 adapter, and a copy of Paul Booth's EECEDitor.
Also, you need a way of programming the j3 adapter, so you'll need an eeprom programmer which Moates also sells a really cheap one that works well, and of course, a $10 adapter. I don't recall which adapter you need, but if you email Craig he's more than happy to help you out.
Replace your VSS first like everyone else said. Your transmission uses that to determine shift points and line pressure. It also uses the Throttle position sensor to determine this also. If the VSS is sending a bad signal to the PCM, and the tranny is thinking it's not picking up any speed, it will stay in 1st gear.
ok i replaced the vss. my speedo bounces around wildy when i hit bumps.. and sometimes down shifts when cruising when this happens, what else is there to replace or fix. also im looking in the haynes and its sayin to adjust the mlps, it just says to adjust it it doesnt say how or why. if its the tps then i got a new onea them also just gotta put it in.
The MLPS wouldn't cause it to jump around in gears. It will cause it to feel like it has popped into nuetral from drive.
If the speedometer is bouncing around, either you got a bad VSS, or the wiring going to it is bad. The VSS is a pretty simple setup. It's basically a magnet that gets a reading off the Pinion gear. If it becomes dirty, the speedometer will lose signal and rapidly gain it back, causing your speedometer to drop and then jump high up. I'm willing to bet at this point that you have a short or a damaged wire leading to the VSS.
so theres no speedo on the tranny or anything? whats the psom? the old vss looked kinda nicked up so im guessin that i should take the rear end apart and clean it in there...the truck has 265k on it
ok.. i ran the codes in the abs system and everything checked out fin except the brake fluid level..fixed that. speedo doesnt bounce as much. now what about the psom what is it? im about to take the rearend apart and clean it, we'll see what happens after that.
