I am not sure I was exited to see you posted in September with no results.... I have a '97 and jsut got the new rad today. I will re post with any tips or headaches I find along the way.
If you did yours and have any to add, I would appreciate it. It appears fairly straight forward.... drain, remove hoses, loosen fan shroud, undue screws and pull right??? LOL, can't be that easy .... I'll repost with any info.
Anyone every do a block heater?? Is this the time to do it or does draining matter?
