vacumm canister
Old Sep 21, 2006 | 01:07 PM
Hiflyer746's Avatar
Hiflyer746
vacumm canister
Hey guys, help me out here,
I need to know where my 2000 7.3 gets its vacumm from to drive the environmental controls and the hubs. Thanks
Tim
Old Sep 21, 2006 | 01:31 PM
Green_Dually's Avatar
Green_Dually
it an electric pump,near the A/C condenser,right behind the batt.
Old Sep 21, 2006 | 02:52 PM
wilbur996's Avatar
wilbur996
The vacuum canister is an oval shaped black thing behind the battery on the passenger side. Just after the canister(going from the front of the truck)is the electric vacuum pump.
If you pull a vaccum hose off a connector you will have a vacuum leak in the system. So if you go and turn the key to have the wait to start light come on, you should here the vacuum pump running. Find where the noise and you will find the pump.
Old Sep 21, 2006 | 06:07 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
OMG thats what that noise is?!?! Every time i turn the key im like "OMG GREMLINS!!"
Thanks, now im not so paranoid....
Old Sep 21, 2006 | 09:23 PM
Hiflyer746's Avatar
Hiflyer746
I'm way confused...
This is some far out stuff,
When I bought my truck, it had a BD exhaust brake on it, so there is a pump just behind the vacumm canister that has a BD sticker on it, so I kinda figured that was to charge the brake. . . so are you telling me that I need to reconnect that and hook up the vacumm lines again? The vacumm line connects into the top of the canister, it looks aftermarket. So wierd.
Tim
Old Sep 22, 2006 | 08:48 AM
wilbur996's Avatar
wilbur996
Take a picture and post in your gallery. Not sure but you need the vacuum pump to run other accessories on your truck.
Old Sep 22, 2006 | 12:33 PM
Hiflyer746's Avatar
Hiflyer746
Yes we figured it out
Hey guys,
I feel kinda dumb here, too much time working on my ol 5.slow. I just kinda figured that it got vacumm from the intake tube before the turbo. . . but I plugged the vacumm line back in from the pump, and plugged in power, and boy, it started right up. I looked at my buddies 6.0 last night, it has basically the same vacumm setup. . . it had the same canister, and just behind it, a very small pump that plugged in at the end of the canister. on mine. . . that very plug at the end of the canister is plugged and not connected into anything, for this new larger pump from BD, that ran a 1/4 inch line to the top of the canister for more sucking volume I guess. I guess the stock pump and small lines wouldn't be enough to feed the 3.0 inch bore air cylinder for the brake Well thanks alot
Tim
bigcrunch
Feb 27, 2016 02:17 PM
Steelhorse
Oct 25, 2015 05:47 PM
bigcrunch
Jun 21, 2015 12:31 AM
elkarcher1716
20
Jun 3, 2015 12:29 AM
cj10488
Jul 1, 2009 04:31 PM
