Leaking tranny vent
Old Sep 20, 2006 | 10:23 PM
FortFord's Avatar
FortFord
Leaking tranny vent
Anyone know what could be causing oil to leak out of the vent on top of a 4r100. The tranny is not overfull and as the level drops it still leaks just as much. It seems to be worse when I'm in reverse or towing a trailer.
Old Sep 20, 2006 | 11:55 PM
Bdox's Avatar
Bdox
Are you monitoring the tranny temperature? How many miles on the unit?
Old Sep 21, 2006 | 12:07 AM
FortFord's Avatar
FortFord
I don't have a temp guage but it does it even when cold. The tranny has about 245000 kms (130000 miles).
Old Sep 21, 2006 | 11:55 PM
Bdox's Avatar
Bdox
The only things that come to mind are overheating or over filling. Since you say it is neither of those, try posting your question in the forum specific to your truck. Maybe someone else there has had the same problem.
I get the feeling there is not a lot of traffic here.
Old Sep 24, 2006 | 09:40 PM
wickymustang's Avatar
wickymustang
Reverse and towing would up the pressure in the tranny so as to not slip the clutch packs. I would think that perhaps your pressure regulation valve is having problems sticking shut, which would make the fluid vent out the tube since it has no way to return to the pan.
Old Sep 24, 2006 | 11:58 PM
FortFord's Avatar
FortFord
How do you go about changing the pressure regulator. I don't have alot of experience inside a tranny.
2000V10USER
Jan 2, 2013 10:56 PM
ptt
Feb 28, 2006 08:22 AM
ptt
Feb 24, 2006 09:09 AM
skooch
1997 - 2003 F150
Aug 2, 2005 08:49 AM
nb1997
Dec 30, 2003 03:28 PM
