1995 E150 5.8L w/E4OD transmission......
Old Feb 23, 2006 | 11:25 PM
ptt's Avatar
ptt
I think I have had a persistant fluid leak caused by overfilling the tranny. Someone referenced that the transmission vent may be the source. Where is this vent located on the casing? Thanks!
Old Feb 24, 2006 | 09:09 AM
masterbeavis's Avatar
masterbeavis
Do you check the fluid properly? Read the owners manual, check the fluid as it suggests. If it shows OK on the dipstick, chances are the trans either has a seal going bad, or it is overheating, causing the fluid to spew out of the transmission.
raye321
Aug 1, 2014 06:20 AM
ptt
Feb 28, 2006 08:22 AM
_Gadget
May 22, 2005 12:23 AM
kconradx5
Jun 15, 2004 08:03 PM
