exhaust vibration
Old Sep 20, 2006 | 09:22 PM
fordboy2's Avatar
fordboy2
exhaust vibration
I have a 4" magnaflow exhaust, and it seems to have a vibrating sound at idle, for instance when you sit at a light. I cant see where it is touching anything, almost sounds like it vibrates against an exhaust shield but therei s at least 1" of clearance, any body have any ideas? it does sound like it comes from close to the fire wall not the rear of the truck.
Old Sep 20, 2006 | 09:30 PM
wolfe1104's Avatar
wolfe1104
have you checked above the rear diff. mine was hitting the diff mine wasnt at idle though, it was while just driving down the road
Old Sep 24, 2006 | 08:29 PM
fordboy2's Avatar
fordboy2
I found my vibration it was the bolts on the exhaust shield, it is so tight where the down pipe turns it was rubbing on the bolts which stick through from the top of the exhaust shield.
Old Sep 24, 2006 | 11:36 PM
ponch37300's Avatar
ponch37300
I had that same problem when i put my 5" on and i took a floor jack and a 2x4 and jacked up against the heat sheild. Probally not the safest thing to do but it did work and no more rattle.
dog2580
1997 - 2003 F150
Dec 30, 2009 08:34 PM
spiritwild
Bronco II
Apr 22, 2007 12:28 PM
kkempter
Oct 26, 2000 03:53 PM
mdrco
1978 - 1996 Big Bronco
Jun 25, 2000 09:04 AM
