Column Shift
Old Apr 1, 2001 | 12:30 PM
ladewigc's Avatar
ladewigc
Column Shift
I need an exploded view of the 3 speed column shift urgantly, mine keeps getting stuck in 1st. All I do is pull the gearbox selector by hand and then it's okay again for a while.
Is the shifts from later models with the same engine compatable with the '66 ?
FORRRRRRRRRRDDDDDDDDDDDDDDDDDDDDD
Old Apr 1, 2001 | 12:55 PM
merc66's Avatar
merc66
Column Shift
I was having the same problem with mine. all I did was lube the shifter at the bottom of the shaft and has been fine ever since. hope this works for you. Rich
Old Apr 1, 2001 | 06:36 PM
64 f100's Avatar
64 f100
Column Shift
Lubrication is good, but if that does not work, parts are easily available to rebuild it. I would rather rebuild and have mostly new as to buy a used setup that might be on its last legs. Have you tried going to your local Ford parts dealer and telling him you need to see a breakdown of the parts. If he has a parts book, most likely he will let you look at the picture. Columns are simple, not to complicated, but kind of a pain in the nuiscance. While you have it out, would be a good time to change the rag joint on top of the gear box. If you have play in your steering, good chance this could be a lot of it. If you can't get a picture of the right parts, I have one of the 63-4. If I can figure out how to do it, I can send you a copy.
Rich
Old Apr 1, 2001 | 07:11 PM
jowilker's Avatar
jowilker
Column Shift
Craig, While you are deciding on what course of action to take, try pulling the shifter toward the wheel when coming out of first, let it fully drop in neutral before going into second. I suspect that will help with your problem. ;-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Apr 2, 2001 | 03:47 PM
ladewigc's Avatar
ladewigc
Column Shift
Thanks for all the posts PPL , but I must remind u all, I am in RSA, I cant even get simple things like headbolts for my 1981 Ford escort. So I need the exploded view of the column for me 2 be able 2 strip the unit and maybe repair it temporary. I need 2 get the truck modile. I will then order all the spares I need from USA (Ford Country).
I tried breaker yards today (20 in total) and found 1 F250 that had no usable spares on it.
SO keep the help comming
THANKS PPL
Old Apr 4, 2001 | 08:52 PM
66ranger's Avatar
66ranger
Column Shift
Had the same problems with my 66 3spd, sometimes, when trying to shift into second, it would be like there was no slot at all for the shifter to even attempt to go in. At the trans, it seemed that the nuts and washers holding the linkage to the trans were worn, replaced them, it seemed a little better. There are several plastic parts stacked together at the bottom of the shift column inside it. If you can, maybe you can very carefully disasemble the column. Make careful notes how everything goes together in relation to other parts. Possibility that some parts may be obviously worn, and could be reproduced using "local" material. If all else fails, there is always the floor shift route..Good Luck!
Old Apr 4, 2001 | 08:57 PM
66ranger's Avatar
66ranger
Column Shift
Old May 7, 2007 | 11:47 AM
inline6ford's Avatar
inline6ford
hello! i have a 1981 ford f100 truck i need to find parts for my shifter. it has a 3 on the tree shifter. the shift tube is broke and i am trying to find a new one. do you guys know where or can give me some web sites or phone numbers to where i can get parts for this column shift?? thanks for your help!
Old May 7, 2007 | 04:59 PM
jowilker's Avatar
jowilker
Try your local Ford dealer. Bill will have the part numbers for you in a little bit.
John
Old May 7, 2007 | 07:29 PM
daveengelson's Avatar
daveengelson
First and foremost, welcome to FTE. Short term fix, perhaps these pic's will be of some help, checked few of the Ford part supplier's website and only came across couple who provide illustrations on their online catalog. In event should decide to purchase any parts, strongly suggest contact by telephone to confirm if part is in stock, if not, suggest trying another supplier. Many of the Ford part supplier's offer free catalogs, handy to have on hand.
May also want to check the shift arm linkage.
url]https://www.johnsf100.com/5766shop/index.htm[/url]
dave
Old May 8, 2007 | 06:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There is a simple reason why the gears hang up. The bushings at the bottom of the steering column are worn. Replace those, and everything is back to normal. The parts are available from Ford, and if you are in RSA (Republic of South Africa?), you can order the parts from one of FTE's Ford dealer sponsors (y2kfordparts or Direct Ford Parts), and they can send them to you.
1-C5TZ-7343-A .. Gearshift Lever Bushing Repair Kit FITS: 1965/72 F100/250
Old May 8, 2007 | 06:33 AM
NumberDummy
FTE sponsor Direct Ford Parts shows the shift tube as available from Ford.
E0TZ-7212-D .. Shift Tube / Fits 1980-87 F100-350 3 speed m/t
Old May 11, 2007 | 08:31 PM
inline6ford
hey thanks for your help! just wondering if there is a aftermarket shift tube and bushings for this truck?? maybe save a little money. keep those straight sixes going!!!
Old May 12, 2007 | 07:25 PM
NumberDummy
Nothing made aftermarket for a shift tube and bushings (which are also available from Ford)...Genuine Ford Parts only.
Old May 12, 2007 | 08:06 PM
inline6ford
hey thanks again for your help! i was just thinking about changing my 81 ford truck to alcohol. it's got the 300/6 in it. 1 barrel carb. what's yall's opinon on this. thanks!
