viton hoses
Old 01-21-2007, 12:21 AM
DNewton's Avatar
DNewton
DNewton is offline
viton hoses
ware can i buy about 30 ft? i need to convert my 6.9 over so i can use B100..... Dustin
Old 01-21-2007, 11:19 AM
newr's Avatar
newr
newr is offline
FWIW
These guy's are right down the road from me, but then, that's most of the way up the coast from you.
http://www.greaseworks.org/viton
Maybe a backup source if nothing else.
Best
Old 01-23-2007, 12:47 AM
roadbike21's Avatar
roadbike21
roadbike21 is offline
I have a 6.9 myself and I was seeking viton lines and o-rings to replace those on my truck so I could run bio and I got a hint from someone on these forums but i forgot who and they told me to simply go to my local hardware store and buy some of that cheap braided clear line hose they sell there and use that instead. It is the BEST thing I have ever done for my truck. It is bio-diesel safe and its clear so you can check and see if you have air in your lines or you can see the quality of fuel running through your lines. Its AWESOME.
Old 01-23-2007, 09:27 AM
newr's Avatar
newr
newr is offline
Wow, that does sound good but it brings to mind some questions. DO you know how it will respond to heat and/or other oils? Do you know the material name?
Old 01-23-2007, 11:20 AM
roadbike21's Avatar
roadbike21
man i sure do not know the material name. you can call your local hardware store though they will know exactly what you are talking about. they sell this stuff in a clear hose and a clear braided line, but I was told to get the clear braided. I have the stuff running from both of my tanks and then all throughout my entire engine. its great cause I can take a peak anytime and see if I have air in my lines (i have had problems with this in the past) so it makes it real convenient. i have been running bio now for like 8 months and the lines are still crystal clear they havent even clouded up or anything.
Old 01-23-2007, 11:43 AM
CheaperJeeper's Avatar
CheaperJeeper
CheaperJeeper is offline
I'd bet money that clear braided hose is vinyl...
Old 01-23-2007, 07:27 PM
DNewton's Avatar
DNewton
DNewton is offline
i was told not to use the clear stuff, because eventualy itll wear away with b100, but if it alright, ill have to go get some, did you also use it for your return line?
Old 01-23-2007, 09:00 PM
CheaperJeeper
FWIW, I've had a piece of the clear stuff without any reinforcement in it hooked up as the return line between the #1 injector and the fuel filter since I bought my truck. No signs of the fuel doing anything to it at all.
Old 01-23-2007, 09:13 PM
DNewton's Avatar
DNewton
DNewton is offline
1. what does FWIW mean?
2. so ill be fine if i hook up the braided vinyl clear line hose for all return lines and fuel lines?
Old 01-23-2007, 09:29 PM
CheaperJeeper
FWIW = For What Its Worth
...and a few more common shorthands are...
IIRC = If I Recall Correctly
LMAO = Laughing My *** Off
ROFLMAO = Rolling On Floor Laughing My *** Off
Seems like it. My piece of clear tubing is only 4 months old - which is why I said FWIW. Dunno' about the long-term yet....
Old 01-23-2007, 09:31 PM
DNewton's Avatar
DNewton
DNewton is offline
well, if its cheap, i dont mind having to replace it.........but then again, i havent had to replace all the hoses yet, so i dont know how much of a pain it is......
Old 01-23-2007, 09:40 PM
CheaperJeeper
OK, well, you've gotta replace all the o-rings under the return caps (the piece on the injector where the return hoses attach). If you don't they will leak air once you disturb them.
The o-rings are a profile # 111. Anyplace that sells butyl rubber o-rings can sell them to you for a few cents apiece. Each injector needs two. When removing them, remove the bottom one first. With the top one still in place the bottom one will "roll" right over the top one and not fall into the groove. Likewise, when installing them, put the top one into its groove first and then the bottom one will just "roll" right on over it and down to the bottom groove.
Assemble the hoses and return caps as an assembly and install them that way after the o-rings are in place. Put a little oil, grease, or vasaline on the o-rings after they are in place and it will make pushing the caps down over the new o-rings a LOT easier.
Good lick with it....
Old 01-23-2007, 09:44 PM
DNewton's Avatar
DNewton
DNewton is offline
ok, so get butyl rubber o-rings with the profile #111?
Old 01-23-2007, 10:03 PM
DNewton's Avatar
DNewton
DNewton is offline
another question, what size hose will i need?
Old 01-24-2007, 01:13 AM
CheaperJeeper
Yup, that would be the direct replacement item. You could always see if they have # 111 o-rings in viton rubber as an upgrade....
Quick Reply: viton hoses
