limited slip 2wd
limited slip 2wd
I have a 99 F-150 2wd. It has a 308 rear end open differential. I would like to change it to limited slip can anyone tell me the easiest way to do this. I would like to avoid having to reprogram my speedometer. Should I get a locker or change the whole rear end? Do they make a 308 that is limited slip?
As long as you keep your 3.08s, you will not need to change your speedo. That, and stock tires.
Here is a list of lockers and LS options for you:
Currie Enterprises Racing Rear End Categories
Not sure if you can find a 3.08 in LS, but if you could, that would probably be the cheapest way to go. Downside is a used stocker may or may not have an "limited" left in the limited slip. They wear out, and you won't really know till you try it.
blloyd29
1999 to 2016 Super Duty
03-28-2016 07:11 PM
Mr_KnowNothing
18
08-25-2014 08:59 AM
kedwinh
09-04-2011 10:50 PM
