Sponsored by: Auxito
limited slip 2wd
Old Feb 23, 2011 | 02:33 PM
ibleedblueoval's Avatar
ibleedblueoval
limited slip 2wd
I have a 99 F-150 2wd. It has a 308 rear end open differential. I would like to change it to limited slip can anyone tell me the easiest way to do this. I would like to avoid having to reprogram my speedometer. Should I get a locker or change the whole rear end? Do they make a 308 that is limited slip?
Old Feb 23, 2011 | 02:57 PM
85e150's Avatar
85e150
As long as you keep your 3.08s, you will not need to change your speedo. That, and stock tires.
Here is a list of lockers and LS options for you:
Currie Enterprises Racing Rear End Categories
Not sure if you can find a 3.08 in LS, but if you could, that would probably be the cheapest way to go. Downside is a used stocker may or may not have an "limited" left in the limited slip. They wear out, and you won't really know till you try it.
Old Feb 23, 2011 | 10:31 PM
phil6608's Avatar
phil6608
Is it a 4.6 or 4.5?
4.6 has an 8.8 rear and 5.4 has a 9.75 rear.
Your changing the diff , not the ring and pinion so yes. You can put a L/S diff in there without changing your gears!
blloyd29
Mar 28, 2016 07:11 PM
Marioj87
2004 - 2008 F150
Jan 28, 2016 05:19 PM
Mr_KnowNothing
18
Aug 25, 2014 08:59 AM
carterjr
Sep 14, 2013 11:37 AM
kedwinh
Sep 4, 2011 10:50 PM
