Offroad & 4x4
So close-
Old Sep 20, 2006 | 02:58 AM
Ford_Six's Avatar
Ford_Six
So close-
Ok, got the axle out of my 72 F100, and it looks so- puny. Especially compared to the D44HD I have to put in it's place. This is the cause for my concern, since my plan includes cutting the radius arm mounts off the old axle and mounting them on the new one. The old D44 has about 2 3/8" tubes, but the new one is 2 3/4". How do I go about fitting the wedges to it? Should I just grind them out on the upper and lower edges, or are they close enough to work without damaging the bushings?
Old Sep 20, 2006 | 11:29 AM
ivanribic's Avatar
ivanribic
Grind them out just a little if you intend to use the same wedges, otherwise you can buy these for the larger tubes: http://broncograveyard.com/bronco/i-...arm_mounts.htm
It doesn't take much clearancing on those to make them fit. Personally I'd opt for the new JBG wedges but I know money is always a factor.
Old Sep 20, 2006 | 06:17 PM
fishmanndotcom's Avatar
fishmanndotcom
when i cut the spring pads off my D60 and welded those edges from JBG they fit right on. all i had to do was make spacer to go between my C's. no problems so far!
-cutts-
Old Sep 20, 2006 | 07:25 PM
Ford_Six's Avatar
Ford_Six
Yeah, I didn't think about a spacer. Maybe I'll just make up some 3/8" shims and let the bushings take the rest of the slack.
fishindave11
1978 - 1996 Big Bronco
Jun 15, 2012 04:21 AM
91Bronc300
Feb 3, 2011 01:05 PM
johnboy427
Oct 5, 2009 02:19 PM
Rintin69
Offroad & 4x4
Oct 26, 2006 03:25 PM
