Replacing reverse bulbs on a 99 navigator??
Old Sep 19, 2006 | 11:29 PM
99RedExpy's Avatar
99RedExpy
Like the title says how do you go about doing that, I tried a few times already and cant figure it out any help would be appreciated thanks.
Old Sep 20, 2006 | 08:14 AM
projectSHO89's Avatar
projectSHO89
Bulb — Reversing Lamp (Navigator)
Removal and Installation
µ 1. Remove the liftgate pull handle.
1 Remove the screws.
2 Remove the liftgate pull handle.
µ 2. Remove the liftgate trim panel.
3. Remove the liftgate watershield.
µ 4. Disconnect the reversing lamp.
µ 5. Remove the reversing lamp bulb.
6. To install, reverse the removal procedure.
If you need the procedure with its drawings, PM your e-mail address to me and I will create a pdf file for you with the relvent sectionof the manual.
Steve
Old Sep 20, 2006 | 09:26 AM
99RedExpy's Avatar
99RedExpy
Thanks alot steve.
Steve
