More vacuum wiper options?
Old Sep 19, 2006 | 10:55 PM
John - NNY's Avatar
John - NNY
Has anyone thought of using some sort of 12 volt vacuum or vacuum pump to run the stock wiper motor? Manifold vacume is maybe about -20 or -25 psi ? I don't know what the CFMs would be. A 12 volt car vacuum may even work. My 337 flathead has the combination vacuum/ fuel pump. A vacuum line runs off the manifold to the vacuum side of the pump and to the wipers. Unfortunatly, I am missing the drive rod for the pump. So, as of now, I am stuck with strait manifold vacuum.
John
NNY
Old Sep 19, 2006 | 11:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's been suggested before (I did once for sure, I think others before me). Manifold vacuum is much more than a vacuum cleaner can produce, but many cars came with electric vacuum pumps over the years (mostly high-end Caddies and such). Thing is, have you ever had to clear snow off a windshield with vacuum wipers? They aren't real powerful even at idle, and the speed is all over the place. Electric is so-o-o much better!
I'd bet Job Lot would have that pushrod for your 337, have you checked them?
Old Sep 20, 2006 | 10:43 AM
John - NNY's Avatar
John - NNY
I agree, electric is the way to go. I just haven't done it yet.
I called Job Lot for the pushrod - no luck.
John
NNY
Old Sep 20, 2006 | 11:31 AM
GLR's Avatar
GLR
Somewhere in the small archives of my memory (way before FTE) a custom magazine had something about a VW elect wiper motor working in a 53. Not sure if it could be adapted to your situation...
Old Sep 20, 2006 | 11:55 AM
Torque1st's Avatar
Torque1st
Posting Legend
Vacuum pumps are available on 80's era Chevy Cavaliers also. If I remember right they were in front of the driver side wheel under the body.
