Towing question?
Old Sep 19, 2006 | 08:17 PM
sawdaddy5's Avatar
sawdaddy5
Question Towing question?
Hello, I hope that this is the right forum to ask my question due to the application.
OK here is my question; I currently have the Hypertech Stage III program in my 2000 F250 SD 7.3 “it came with the truck when I bought it” and I have tried to do a search on the boards about which setting is best for towing. I have pretty much used it in the stage 3 99.5% of the time, but began to wonder if the stage 3 was the best for towing.
I am soon going to be towing a 28’ fifth wheel camper around 8K lbs. down to Florida for vacation which will probably be a 800 mile trip and was hoping if someone had any advice.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I understand that the DP tuner is seemingly the best tuner for my application, and as soon as I can afford it I am defiantly planning on giving Jody a call.
<o></o>
John
Old Sep 19, 2006 | 08:24 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
well, if you have no gauges to monitor the temperatures, then i would leave it in stock, or at most, the first (lowest) setting. 8,000 pounds is alot, and with a stock exhaust and intake, things can heat up and melt pretty quick.
Old Sep 19, 2006 | 08:29 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Agreed. So long as you have the ability to monitor the situation you can use any program you choose, but if you don't, you should stay as close to stock as possible.
Bare bones minimum you need a pyrometer to keep an eye on exhaust gas temp when towing with any programmer.
Old Sep 19, 2006 | 08:38 PM
bigtorque's Avatar
bigtorque
i agree with strokin, no gauges, no programmer, though if you have gauges, alot of folks say you can tow in any setting just as long as your watching your gauges, but most manufactures state not to tow over 5000lbs with more than a 40 hp. 120 lb. torque program. I currently tow 13000lbs with gauges, no program, 4 in T/B exhaust and tymar intake. W/ZERO PROBLEMS- keep watching this thread, im sure you will be able to make up your mind what to do in a day or so.
Old Sep 19, 2006 | 08:45 PM
fordboy2's Avatar
fordboy2
Gauges are a pretty cheap investment, considering the cost of repairs if things go wrong. I would try and get some gauges even if you decide to run in stock mode just for peace of mind. Just my opinion though!
Old Sep 19, 2006 | 09:05 PM
PowerstrokeJunkie
if you have the ability to harness the power (such as transmission cooling) and gauges to monitor things, you can run in the Race program, as long as you can keep the EGT in check.
Old Sep 20, 2006 | 02:40 PM
bigtorque's Avatar
bigtorque
not to be thread robbing,
but do all of you run on the highest setting no matter what your doing, ie/ towing 8000 to 13000 lbs. now understanding gauges are key, can you have too much power on a 7.3 while towing. lets say program running 120 horse, 210 torq. while towing. that would put a modified 7.3 close to 400 horse and 800 torq. any thoughts.
Old Sep 20, 2006 | 03:16 PM
Kwikkordead's Avatar
Kwikkordead
I tow my trailer with the Diablo Predator Tow/Haul tune. It's about a 40hp tune and I still manage to get the EGT over 1250 if I push it.
I have the AIS, 5" exhaust and the wastegate is connected. Boost pushes 26-27 psi on a big hill at 2500 rpm.
Without guages you are, for sure, going to go out of the safety zone with that tune.
Old Sep 20, 2006 | 07:22 PM
PowerstrokeJunkie
you cannot just take the stock output numbers, and all the HP and TQ gains of your mods and come up with a number. with a 100 tune and my mods, i made 283hp and about 568tq, and on 140, it only increased 8 hp over the 100, being 291hp and 579tq.
Old Sep 20, 2006 | 07:52 PM
maevans's Avatar
maevans
fficeffice" /><O></O>
<O></O>
John
Hello John,
I'm using the Hypertech programer, in the # 3 setting for everything( because it's a pain in the butt to change, takes about 4 times to take the new program ) When I'm towing my 11k toybox i can keep the EGT under 1,000 degs with no problems by watching my gauges. So like the guys have already said - GET GAUGES. And i will also be using a DP tuner soon and give away the Hypertech.
Old Sep 20, 2006 | 11:49 PM
bigtorque's Avatar
bigtorque
hey strokin, have you been to a dyno to get those numbers,
i do know the stock numbers are ran off the crank shaft, so for sure the RWHP numbers will be lower, but i can only assume if a manufacture is selling a product that adds 100 hp, im assuming its crank shaft hp and will vary for each application.
at least thats my understanding........
Old Sep 21, 2006 | 08:29 PM
sawdaddy5's Avatar
sawdaddy5
Thumbs up
Thanks for all the reply’s guys, and it looks like I will be investing in some gauges soon. I will be towing the camper to talledega Al<ST1</ST1 in the next couple of weeks but I doubt I will have the funds until then so I will be sure to put it in Stage 1 and be sure not to tax the engine until I have a method for monitoring the temps and boost.<O</O
Also didn’t I read that DP has or will soon be coming out with a system to monitor these pyrometers?
<O></O>
Thanks Again
John
Old Sep 21, 2006 | 08:45 PM
cookie88's Avatar
cookie88
FTE Emeritus
Chip are rated in rear wheel horsepower, but the assumption is being made that the supporting mods are there.
A completely stock 7.3 will dyno somewhere between 185-215 RWHP. A 100HP tune will add approximately 100RWHP to that if you can make use of the available fuel. A big intake, big exhaust and 100 horse chip will add ~100 horsepower, doesn't matter where you measure it.
Adding a 100HP tune with no supporting mods will still get you 60-70% of the advertised power, but it will be accompanied by enormous clouds of black smoke and uncontrollable EGT's.
Old Sep 21, 2006 | 08:55 PM
white Buffalo's Avatar
white Buffalo
I have a Tony Wildman (totaldieselperformance.com) 4 position chip and two of the positions are tow programs. One is @ +40 Hp and I use that in the Black Hills & on trips to the Rockie's. The second is @ a +80 HP tow and I use that on the flats. Just like everyone has said they key to running any program while towing is watching the guages. No matter who's chip you go with I would suggest getting your tow programs shift points for Overdrive changed to 55 mph. It gets to be a pain in the A$$ to have to mash the OD drive button so it doesn't shift to OD at 45. Just a nice feature I'de though you might be interested in.
Old Sep 28, 2006 | 07:08 PM
ramprat's Avatar
ramprat
towing
i tow those rvs for a living and the 8000 lbs is nothing for your truck. i max out at 12500 with a stock 444 motor. but for what you have gauges would be a good investment. have fun
