From Dino to Syn
Old Sep 19, 2006 | 05:26 PM
roadtech's Avatar
roadtech
From Dino to Syn
Would like to know how many miles I should have on my 6.0 before I change to Syn. oil .
Old Sep 19, 2006 | 06:23 PM
utahtom's Avatar
utahtom
The general rule is 10,000 miles. I am planning to switch over at 15,000 miles and probably would have done it sooner (less miles) but coinciding my switch from 15W40 to 5W40 with the arrival of the Winter season/cold weather.
Old Sep 19, 2006 | 07:57 PM
dentaldave's Avatar
dentaldave
utahtom: sorry to butt in... but I have a question... once you switch to syn at 15k, will you stick with the syn 5w40 during summer months... in other words... will you just use the 5w40 year round? All other opinions welcome.
Old Sep 19, 2006 | 08:00 PM
PSNut's Avatar
PSNut
The 5W-40 syn is suitable for year round use.
Old Sep 19, 2006 | 09:57 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Mobil and Rotella say "anytime is good" and no break-in is required.
Others say to wait.... so do what you think is best and I am with the "wait for at 10,000 miles (at least) group.
I use Rotella-Syn 5W-50 year round and all is well.
Here is a twist though.... the magazines I have read have stated that the new diesel oil spec of CJ4 is far superior than the current CI4+. I may actually switch back to Rotella dino oil in October when the new CJ4 spec is made available in gallons. Do a search for "CJ4 oil" and look at the current issue of "Diesel Power" Magazine for more info. The new oil spec of CJ4 is so much better than CI4+, that I am going back to CJ4 dino oil (until the synthetic version is made available).
Old Sep 19, 2006 | 10:00 PM
roadtech's Avatar
roadtech
Thanks for the reply guy's, that is about the time line I was thinking about. I sold my 99 s/d 7.3 to my son with 350,000 still working like new. I have been using 0W40 syn
in that engine since 104,000 winter and summer and changed it every 10,000 km. It is a little more money, but you get what you pay for, and my tech says oil is the cheapest thing you can do to a diesel.
Old Sep 19, 2006 | 10:21 PM
utahtom's Avatar
utahtom
Excellent question- I intend to stay with the 5W40 during the summer months... Although I tow very heavy loads during high temps at higher elevations and will have oil analysis performed.
FWIW: The latest DuraMax Owners Manual specifically does not recommend using 5W40 above 100 degrees. Instead, they recommend 15W40 which I find quite interesting. I have not read/seen any other differentiation (between the 2 weights) during high temp operation.
Old Sep 19, 2006 | 11:46 PM
LVEILLON's Avatar
LVEILLON
I've considered it many times, but since I keep my oil change intervals so close and my maintennce plan pays only for FORD DINO...I'll probably stick to it Dino and possibly add an OilGuard filter for more benefit. I believe that if you live in the colder climates that you may benefit from the synthetics especially in the winter for easier starts.
