Personally, I don't think it is worth it. the only REAL thing I use the overhead console on my truck is for my sunglasses. I don't ever use that first compartment (for remotes) and rarely look at the ambient temperature and current directional compass. But that is me.........
If you want to add the overhead console, you would need to mount it somehow (OEM is factory spot welded bracketing on the underside of the roof to accept the unit chassis cover) and you would need to run the wire harness. Also, the headliner's are different at the overhead.
