'04 Lariat temp reading inaccurate
Remove it from the holder, use a ohmmeter to test between the two leads on the sensor. The reading should be between 8000 and 14000 ohms at 65-80 degrees F.
If its not in that range, you need a replacement at over $100.
There is nothing you can do to fix it....I tried everything from resistors to wrapping. Even had it diconnected for a while but it bugged the hell out of me.
