1st modification
Old Sep 23, 2006 | 09:19 AM
FARM69's Avatar
FARM69
If your simply trying to remove the cat just break out the Sawzall and cut er off. That would be the easiet less painful way to accomplish the job.
Old Sep 23, 2006 | 09:57 AM
Copedawg's Avatar
Copedawg
Well Farm, I need the back end of the cat out of the rest of the exahust so I can slip the delete in. I was thinking cut it then try to "chip out" the inside. Would that be a wise move?
Old Sep 23, 2006 | 10:05 AM
Stroker 94 1/2's Avatar
Stroker 94 1/2
If the delete pipe goes in place of the cat just stick it up there measure the pipe and cut it off then slip the delele pipe in. Thats how mine worked.
Old Sep 23, 2006 | 10:12 AM
Copedawg's Avatar
Copedawg
Stroker, so If I cut the cat (that is slipped in the rest of the exhaust already) you say the delete pipe will slip in the cut cat that is slipped into the rest of the exhaust? Sounds tight. Or maybe I am not understanding what you are saying.
Old Sep 23, 2006 | 10:16 AM
Stroker 94 1/2
If the end off the delete pipe is expanded it should just slip right over the rest of the exhaust and the other end should slip into the new down pipe.
Old Sep 23, 2006 | 10:19 AM
Copedawg's Avatar
Copedawg
hmmmm, I just assumed it was smaller then the rest of the exhaust and slipped in...I didn't realize it was bigger! lemme check and see, TY!
Old Sep 23, 2006 | 10:23 AM
Stroker 94 1/2
I think you can check it by sliding it over the tail pipe at the end of your exhaust? It should be the same 3 1/2" pipe.
Old Sep 23, 2006 | 10:25 AM
Copedawg's Avatar
Copedawg
The pipe does not seem to get bigger at the end suggesting it slips over the rest of the exhaust. Perhaps I will call the manufacturer and ask.
Old Sep 23, 2006 | 10:28 AM
Copedawg's Avatar
Copedawg
It is the exact same size as the outlet of the tailpipe
Old Sep 23, 2006 | 10:44 AM
Copedawg's Avatar
Copedawg
So if it is the same size, it will slip over the exahust pipe at the end of the cat between the cat and muffler?
Old Sep 24, 2006 | 08:04 AM
Copedawg's Avatar
Copedawg
All righty then! Delete installed. Its amazing what the right tools can do. I used Oxy/accet and a BFH and that cat popped right off. I cut the delete down a little and wire wheeled the inside of the old exauhst and slammed that baby in place. I could not get it all the way in. There is a hole on the exauhst that is exposed (the whole looks porpously made from the factory I dont know why) I am not sure what to do with the hole. Any suggestions?
THANKS
HOOOOGA!
Old Sep 24, 2006 | 10:11 AM
Stroker 94 1/2
Good to hear you got her done! If you have access to a welder just weld it together so it wont come apart on ya. Where is the hole? Is it on the down pipe?
THANKS
HOOOOGA!
Old Sep 25, 2006 | 03:29 AM
  #28
Copedawg's Avatar
Copedawg
Actually its on the pipe between then test pipe and muffler and it is just about where the clamp is on the test pipe side. I will find a band aid for it, thanks!
HOOOOGA!
Old Sep 25, 2006 | 10:19 AM
  #29
Stroker 94 1/2
Next the muffler will be gone.
Old Sep 25, 2006 | 10:53 AM
  #30
Copedawg's Avatar
Copedawg
I ran with just the down pipe on to work to finish the project. It was to loud (I drink to much so I don't want to attract attention) So I think I will the muffler.
Top_Speed1
Apr 19, 2017 04:01 PM
aperry619
New Member Introductions
Oct 14, 2016 08:27 AM
SKeeeTTZzZz
Aug 23, 2015 11:32 PM
acf6
Mar 12, 2013 09:33 AM
SWAT KHAN
1997 - 2003 F150
May 13, 2012 09:52 PM
