what degrees???
Old Sep 19, 2006 | 12:31 AM
dieselburner6.0's Avatar
dieselburner6.0
what degrees???
when i set up my distributer to number one, should the crank be at TDC or a few degrees advanced? it has a eldelbrock performer plus cam in it. thanks
Old Sep 19, 2006 | 12:33 AM
monsterbaby's Avatar
monsterbaby
I usually set the crank at about 15deg advanced according to the pointer when I put the dist in that seems to give it a better chance of firing right up. It will actually fire before that point just a slight amount, typing it isn't getting it across clearly but thats what I do.
Old Sep 19, 2006 | 12:27 PM
greenhighboy's Avatar
greenhighboy
I do the same thing. Put the dist. in with the rotor pointing at the #1 plugwire and the timing pointer on about 10-12 BTDC on the balancer. The engine should fire right up without turning the dist.
Old Sep 19, 2006 | 06:24 PM
WILDEBILL308's Avatar
WILDEBILL308
I think the reason this workes so well is that the Dist and cam gears are curved and if you try to put the distrib in with the crank at TDC and the rotor pointing at the #1 plugwire the roter will turn and it will be about 10 degreas retarded. This is a great tip to help get that new moter started the first time it's cranked. I find this to be a great reliever of stress
Bill
Old Sep 19, 2006 | 10:48 PM
dieselburner6.0
thanks, i put the dist in before the motor was in the truck, but when i went to take it off the stand i noticed the balancer was a degree or 2 BTC so pulled it out and realinged to TDC, the motor is now in the truck but shouldnt be to bad, ill just have to turn it over a few times to figure out when the compression stroke on number 1 is, and then drop it back in at 10- 12 degrees .
Old Sep 19, 2006 | 10:54 PM
dieselburner6.0
i forgot to mention that i have the edelbrock roller timing gear set, and performer plus cam, even with those goodies the recomendations above still applie?
Old Sep 20, 2006 | 12:33 AM
monsterbaby
those recommendations apply to all combinations and motors I use the same procedure no matter what I am working on.
danocross
Aug 24, 2020 07:39 PM
BstangBill
Sep 22, 2016 01:48 AM
tractormanbill
32
Jul 18, 2016 10:53 AM
amdriven2liv
Nov 23, 2015 10:36 AM
amdriven2liv
General Diesel Discussion
Nov 12, 2010 05:13 PM
