Fuel Tank
Old Sep 18, 2006 | 02:47 PM
VHOLT's Avatar
VHOLT
Fuel Tank
I have decided to replace the sending unit for fuel guage myself. Has anybody removed the tank and done this. Just wondering how difficult it will be. Any help would be great. VHolt. 00 x V10. 118,000 miles and counting
Old Sep 18, 2006 | 08:00 PM
mcamalong's Avatar
mcamalong
I will be watching this post as my fuel gauge only will work 1/4 tank and below. I have a 2002 Ex 67k on it.Does your gauge work at all? Thanks Mike
Old Sep 19, 2006 | 12:30 AM
aklim's Avatar
aklim
http://www.itpdiesel.com/other/FuelS...ankRemoval.pdf
Old Sep 19, 2006 | 02:43 AM
RACERX7775's Avatar
RACERX7775
Aklim, Perfect Link..
Old Sep 19, 2006 | 09:19 AM
VHOLT's Avatar
VHOLT
My guage reads full all the time. The miles to empty on the lie-o-meter jumps between 450 and 550 depending on the day. I'ts been this way about a month. Took it to the stealer and they wanted $380.00 for repair. Looking at the truck, it looked like when you remove the skid plate and disconnect the filler tube and vent it should drop down. I quess I'll find out. VHolt 00x V10
Old Sep 19, 2006 | 03:30 PM
Lonewolftx's Avatar
Lonewolftx
Arrow Not a big deal . . .
The skid plate takes a 13mm socket (4 bolts) and the tank straps takes a 10 mm (7 bolts). Also slip off the fuel filler and vent tubes behind the fuel fillup door. Each has a screw clamp.
  • Lower to the floor, it helps if the tank is empty
  • There is a vent slide on tube up by the fuel filler tube.
  • slide out the left rear wheel well, if you have a 4x4 then you might not need to take the left rear tire off but if you don't you will have to.
  • Sending unit is in a 6" hole in the center of the tank. You need a strap wrench to lossen but mark the position before removing to know how tight to make it when you put it back togehter
  • Work away on the challenge at hand
  • reverse the process. . .
You can check out Harpooning the tank in the diesel section for more detailed instructions as well.
Old Sep 23, 2006 | 03:13 PM
mcamalong's Avatar
mcamalong
Hello, Well I droped the gas tank today it was pretty easy. The question I have now is how do you remove the fuel pump/sending unit it seems to be attached to the bottom of the tank. Also is their a sending unit to replace or do I have to replace the entire pump unit with the float control. Thank You Mike
Old Sep 25, 2006 | 08:30 AM
Lonewolftx's Avatar
Lonewolftx
Arrow
It should just pull out the top. Is the SS plate stuck to the rubber gasket under it? It isn't mounted to the interior of the tank so you might need to pry it up after you take the retaining ring off. All there is in there is the pickup tubes and a float for the fuel level monitor.
Old Sep 29, 2006 | 11:34 AM
VHOLT's Avatar
VHOLT
Well I took the tank off yesterday. thanks Lonewolftx and RACERX7775 for the link and advice. Pretty easy really. My sending unit was not bad, the float had hung on a wire in the up position. Thanks again for the help. VHolt 00x V10
Old Sep 29, 2006 | 11:41 AM
Lonewolftx's Avatar
Lonewolftx
Great . . .
That's why we are here, to help each other out.
Old Oct 1, 2006 | 05:29 AM
kids_ride's Avatar
kids_ride
Anyone ever review the option to just cut a hole in the floor and add an access panel.
This is the same setup as the Range Rover (my 95 has a factory installed panel) most DIY'rs add the panel once they have to get there one time.
Old Oct 2, 2006 | 08:20 AM
Lonewolftx's Avatar
Lonewolftx
Arrow WHy?
No real interest on my part to cut a hole in my truck bed to access the fuel tank. It is only a few bolts and the filler hole for access to the whole thing and w/o fuel in it, it is easy to get off.
Wjhy cut a hole in your truck bed? How many times do you want to access the fuel tank top anyway?
Old Oct 2, 2006 | 09:42 AM
SSGG's Avatar
SSGG
I think it would be a better option for the Excursion, especially mine, since I had to cross thread one of the bolts back in and the shroud is very, very heavy.
Wes
LEDman
Sep 15, 2016 01:28 AM
timpage
27
Aug 10, 2016 10:53 PM
swampthang
Mar 3, 2014 12:49 PM
superrangerman2002
Oil & Lubrication
Sep 5, 2002 10:32 AM
TKONO
Apr 19, 2002 07:37 PM
