Aerostar Ford Aerostar
IAC problems.....
Old Sep 18, 2006 | 12:12 PM
Pablo-UA's Avatar
Pablo-UA
Unhappy IAC problems.....
I have 1 problem - IAC does not work. The problem is, that solenoid is ok, but no signal from ECU. I have +12 V on 1 terminal of solenoid, but I have to press throutle till engine is warmed up. Is there any fuse in wires leading to ECU, tommorow I will chech wiring, but it seems to me key in ECU is bad... Who ever replaced it, where is located, and what key to use.....
Thanks!
Old Sep 18, 2006 | 01:20 PM
96_4wdr's Avatar
96_4wdr
ECU IAC output transistor grounds one IAC lead completing circuit and activating solenoid air valve
pin 21 on '93 3L ECU/PCM, white/lt. brown lead...i don't have EVTM for '89
test for continuity from IAC plug to ECU
test for ground at idle
Ford ECU's are very reliable...suspect everything else first
will even take 24v reverse polarity jump
Old Sep 18, 2006 | 01:22 PM
Pablo-UA's Avatar
Pablo-UA
no ground on idle!!!!!!
Old Sep 18, 2006 | 06:59 PM
96_4wdr's Avatar
96_4wdr
ECU from Aero/Ranger/Explorer 3L up to about '92 should work...'92 >'93 is when Ford changed from bank injection to sequential port injection
2 injector driver circuits on older 3Ls....6 driver circuits on newer 3 Ls
or if you wanted to pull ECU wiring harness and injection harness plus ECU from newer 3L....make your '89 a sequentially injected dragstrip Killer
Old Sep 19, 2006 | 12:17 AM
Pablo-UA's Avatar
Pablo-UA
The first Idea - to open ECU and to replace transistor key, but I have no info....
I do it periodically with MB ECUs, but I habe many bad ECUs to do some experiments... I have only 1 ECU...
Yeah I have Idea to replace it, from '92-95 2.9V6 scorpio (Cologne engine)...
Old Sep 19, 2006 | 04:55 AM
96_4wdr's Avatar
96_4wdr
Ford publishes nothing on the ECU/PCM components and firmware...trade secrets...most of the surface mount components do not even have markings....Intel used to do Ford's ECU controller chips and ECU design
Old Sep 19, 2006 | 07:16 AM
Pablo-UA's Avatar
Pablo-UA
DaimlerCrysler does it to.... So I use x-rais to understand what is inside! But ECU is ruther cheap, abot $50 used here. I'm not sure, I guess 2.9 V6 Scorpio ECU fits aero....
MBAGDON
Electrical Systems/Wiring
Mar 17, 2025 04:47 PM
biofused1
Feb 3, 2015 01:42 PM
mitch_c
1983 - 2012 Ranger & B-Series
Aug 6, 2014 10:57 PM
brandonnichols
Mar 31, 2014 06:58 AM
fordf350camper
Computer Chips & Tuners
Jun 27, 2013 09:19 AM
