The TSB applies to 2004 5.4l. Does this mean that I have nothing to worry about with my 2005? Was there a change to the clearance or a plug material spec change in 2005 that truly fixes this problem?
Hate to say it my next one will have a vortec in it a back yard mechanix can change the plugs in about 30 min. less if you are a real mechanic ford has really got a mess with these heads and they will not do a thing to help, mine is also an 04 and my last.
i can change mine out in 30 minutes or less. well actually my wifes cause i dont have a 1/2 any more. hers is a 04 and we did'nt have a plug problem, but my 05 did. for the life of me i dont understand why the guys here that know theres a problem wont spent the time to check it out their selves. they dont trust the dealer to check it and tell them the truth, but yet wont pull them their self. Then they turn around and bash on ford. if you want a vortec there is tons of them out there, by all means knock your self out.
Answer me one question since 04 ford had probably sold in excess of 3 million 5.4 engines and they know they have a head problem and will not do a thing about it why is this?? Also I did check mine at 32K every plug is showing rust and corrosin build up and ford says you don't even need to look at them for 100K if you have any answers would like to hear them????
I read a very good article on this plug problem and the reason Ford doesnt stand behind them is they can't afford to, which of course is no excuse. Their already near financial collapse so to avoid the expense of admitting their mistake they prefer to blame the spark plug LOL. I would like to know what they were trying to achieve with this design that led to this problem-ws it suppose to give better gas mileage?burn? what?
I think you are exactly right on why they won't do anything and also I don't think the engineers had a clue as to why they did it like this except it must be cheaper somehow it sure as hell doesn't help mileage or power any!!!!!!!!!!
Since it is not clear that the problem has been completely isolated, how do we know that replacement plugs won't have the same problem? I don't mind changing my plugs out if it truly solves the problem.
Ted928 I have access to Ford online service info.
I wish I could tell you more about this issue but I could loose my job.
I will tell you it's a good idea to take the plugs out using the TSB and let the penetrating oil soak in longer then 10 minutes.
So what your saying, is that this is NOt the same issue prior 5.4's were having with "spittin out plugs" due to not enough thread in the head(ha ha I made a funny )?
I read a very good article on this plug problem and the reason Ford doesnt stand behind them is they can't afford to, which of course is no excuse. Their already near financial collapse so to avoid the expense of admitting their mistake they prefer to blame the spark plug LOL.?
That's the same reason GM wouldn't address the piston slap issue with their trucks from 1999-2004. They repaired them in the beginning but once they discovered how widespread the problem was due to the millions sold and it was more a noise issue than an imminent failure, they determined that the cold engine noise was "normal".
The problems are not safety related so no recall is required.
The plug is a very different design, they moved the threads to the middle of the plug, so the part of the plug that goes into the chamber could have a much smaller diameter, to make room for the 3 valves. Its a whole new design made just for this engine, and therefore had no history, so ford couldnt have known it would be an issue. Hindsight is 20/20, the design of the plug really cant be altered much, but perhaps some antisieze or maybe an impregnated bronze sleeve could work to help it from sticking.
I don't see any reason not to use anti-seize when installing the new plugs. Seems like its a good idea to look into doing this every 20k miles to be on the safe side.
there is no reason not to use it, but not only on the threads, i would apply a VERY THIN LAYER on the part of the plugs that extends through the cylinder head. not on the top, but the sides.
Yeah i read about it all over on ford forums so i went out and took care of my 5.4 04 to clean it up then put it back in...to avoid become stucks in!
My truck has 25K on it thats when i cleaned the spark plugs..will do it again next 25K.
Just for extra insurance...unless if theres some good company new releaae special spark plugs for 5.4!
