ccv mod?
Old Sep 18, 2006 | 10:16 AM
herman2001's Avatar
herman2001
ccv mod?
I was wondering if there is a modification to stop the crank case ventilation from going to the intake I know the big trucks Peterbilt, kenworth the older cats do not have this is there a way to have fresher colder air going to the intake without the mess of sloppy oil residue filling up the air to air if so please let me know thank you in advance...
Old Sep 18, 2006 | 10:33 AM
Uzumati's Avatar
Uzumati
I think you allready found the thread I started, but for a kit check out
http://www.puredieselpower.com/catal...f921cbb9739da8
Old Sep 18, 2006 | 06:18 PM
herman2001's Avatar
herman2001
There must be a home made type deal to perform this mod, 100.00 bucks for some heater hose and a clamp seems a bit high..let me know....thank you
Old Sep 18, 2006 | 06:49 PM
HeatStroked's Avatar
HeatStroked
Here is a kit from ITP diesel....
http://www.itpdiesel.com/store.php?c...on=show_detail
Old Sep 18, 2006 | 07:03 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I have the ITP kit now because I like the aluminum tube that replaces the plastic stock tube. The ultra cheap version of this mod is to simply plug the hole in the intake connector and splice a hose into the valvecover fitting to route it under the truck.
Old Sep 18, 2006 | 07:15 PM
Uzumati's Avatar
Uzumati
If you wanted to get all the parts I think you could do it <30 bucks or so
Hose, 400* Heat rated PVC elbow, 4" muffler pipe
