Oil & Lubrication
Coastal Mercon
Old Sep 18, 2006 | 08:30 AM
BEAL73's Avatar
BEAL73
Coastal Mercon
This has probably been brought up before but I cant seem to find any arguments on it. Anyway, does anyone have any problems Using the Coastal Mercon Fluid? It was $7.98 a gallon at AutoZone. Is this comparable with Motorcraft and Castrol?
Old Sep 18, 2006 | 09:30 AM
MrBSS's Avatar
MrBSS
Generally, if it passed the spec, then it passed the spec. I guess it ends up a question as to how much you trust Coastal.
Personally, I have no knowledge of any problems with that product, but then any problems with a trans fluid could take a long time to surface. One always has to question the cheaper product, but today, so much is marketing that its hard to tell if you really get more by paying more.
Old Sep 18, 2006 | 07:14 PM
ford390gashog's Avatar
ford390gashog
it does meet the mercon spec and will not harm a thing. but at 1.99 a quart its a little steeeep. The supertech brand from walmart has a better basestock and add pack for 1.68 a quart
Old Sep 18, 2006 | 10:23 PM
bruce381's Avatar
bruce381
I vote for super tech since I have used in the expy and exploder NO problems.
bruce
Old Sep 19, 2006 | 07:32 AM
kotzy's Avatar
kotzy
I'm sure it is ok, no one wants to be in the situation Quaker State was in back in the
70's it cost them a bunch of money as well as loyal customers when they sold a bad product.
Old Sep 21, 2006 | 09:46 PM
e250guy's Avatar
e250guy
Do NOT use Coastal if you have a transmission that calls for Mercon V. It's not the same. Eventhough the bottle claims "for use in all mercon required transmissions". Mercon V has an additive that Dexron/Mercon does not and is vital to proper trans. function and longevity.
I snooped around quite a bit on this forum and in general and discovered our 02 explorer trans NEEDS the Mercon V. Anything else will cause it to fail very premature (not that it's not already prone to failure as it is)
If not, I'd go with the supertech.
Old Sep 22, 2006 | 10:24 PM
BEAL73's Avatar
BEAL73
This is in a 92 with A4LD trans. It does not require Merc V. Thanks
Turbo Dog
Aftermarket Products
May 17, 2014 09:54 AM
tdpower
May 15, 2010 10:08 PM
Agapemou
S. California Chapter
May 28, 2006 03:45 AM
KubotaOrange76
Oil & Lubrication
15
Apr 3, 2006 10:17 AM
bradcdavis00
Oil & Lubrication
Nov 29, 2005 09:38 PM
