Vent window seal installation
Old May 5, 2001 | 09:45 AM
6t6merc's Avatar
6t6merc
I can't figure out how to squeeze the little brass rivets used to hold these seals to the division bar. Dennis Carpenter has not replied to my request for help. A special tool maybe? Any ideas?
Eric D
Old May 5, 2001 | 11:23 AM
jowilker's Avatar
jowilker
Call Carolina Classics Monday/Friday 800-598-4211 Rickey can help.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old May 6, 2001 | 01:23 PM
skip4274's Avatar
skip4274
Eric. The rivets are for putting the little curved mounting arm on the division bar, not for the rubber seal. To buck the rivets, I use a small dab of glue, yellow weatherstrip adhesive (gorilla snot) or what ever to hold the mount to the bar and the rivets in the holes, then I put a flat faced punch in a vise, hold the assembly over the punch (the punch on the flat face of the rivet) and very gently with a small ball-peen hammer tap the end of the rivet to flatten it out. Look at your old assembly and you will see what I'm talking about.
Hope this makes sense.
Skip4274
Old May 6, 2001 | 05:22 PM
6t6merc's Avatar
6t6merc
Actually, Skip, there are five small rivets supplied to hold each vent edge seal to the division bar. It sounds like your method will work if I can round up a second pair of hands...Your advice is a lot better than Dennis Carpenter's: "Remove the division bar and have someone rivet the seal in place". (!)
Eric D
Old May 14, 2001 | 04:30 PM
jimarlie's Avatar
jimarlie
Old May 14, 2001 | 11:01 PM
packrat_1954's Avatar
packrat_1954
Eric What I done to set the rivits you are talking about was to cut off a "nail set" so the end was about 1/4 in dia. Then I chucked it up in my lathe (you could use a drill clamped in a vice) and run it at high speed ..then with my Dremel tool with a small rock bit, I concaved the end of the punch, to set the rivit..will have to hold a backup on the other side of the rivit...Packrat_1954
markeyd
13
Jun 18, 2015 12:56 PM
chewyacura
Feb 17, 2014 10:06 AM
Donordad
Modular V10 (6.8l)
Jul 8, 2013 07:06 PM
Jay_ford476
1997 - 2003 F150
May 25, 2013 07:56 PM
