New cab mounts
Old Apr 8, 2001 | 12:18 PM
66merc's Avatar
66merc
New cab mounts
I've bought a set of Energy Suspension cab mount rubbers for my '66. The ones that came out measure 7/8" thick, although they might have compressed a little over 35 years. The new ones are 1 1/4" thick. I'm concerned that this difference will cause problems, perhaps with the rag joint and with the alignment of the cab trim to the box trim. Does anyone know what the OE thickness is supposed to be, or has anyone put this kit in a 65/66? ( The kit is labelled '73-'79, but Energy Suspension told me that the kit fits a '66.)Thanks.
EricD
Old Apr 8, 2001 | 06:39 PM
66worktruck's Avatar
66worktruck
New cab mounts
They should work fine. Mine did.
Old Apr 25, 2001 | 06:52 PM
6t6merc's Avatar
6t6merc
New cab mounts
As it turns out, the difference in thickness is critical. With the new mounts correctly installed, and the cab put in place and snugged down, the steering column will not go in. I'll be sawing them to the correct thickness. Live and learn.
Eric D
Old Apr 25, 2001 | 07:13 PM
skip4274's Avatar
skip4274
New cab mounts
Eric. You shouldn't have to cut down the new mounts. Just loosen the saddle under the dash that holds the steering column to the dash so it can slide up and down until you get everything put in. You did get the cowl support mounts too didn't you? The body line won't line up if you don't replace them too.
I would always remember the carpenters advice, measure three times for every cut you make.
Old Apr 25, 2001 | 07:22 PM
6t6merc's Avatar
6t6merc
New cab mounts
Actually, skip, the column would have to go up at the wheel end and there is of course no adjustment for that. The column goes in but the collar on the firewall sits 3/4" above the tube and the tube contacts the firewall and prevents the rubber sleeve and retainer plate from attaching from behind correctly. I anticipate also that I will experience a similar problem with the clutch linkage and brake lines if I continue. Thanks for looking on the bright side, though.
Eric D
Old May 13, 2001 | 06:55 AM
Nathan's Avatar
Nathan
New cab mounts
Old May 27, 2001 | 09:32 AM
65styleside's Avatar
65styleside
New cab mounts
I was wondering what you figured out on the cab bushings? I am getting ready to do the same to mine, and I don't want to get the wrong ones. They told me the same thing about those 73-79 working on my truck.
Old May 27, 2001 | 10:24 AM
6t6merc's Avatar
6t6merc
New cab mounts
I hacksawed them down to size. What a waste of time and money. Have a look on the 67-79 page for the discussion.
Eric
dmack91
Jun 29, 2013 11:12 AM
shanes66charger
Oct 25, 2012 10:35 AM
Sheryle
Aug 23, 2011 12:07 AM
93BigBlackBronco
1978 - 1996 Big Bronco
Apr 8, 2005 09:27 PM
aunchman
Aug 20, 2002 09:49 PM
