302 efi to carb
Old Sep 17, 2006 | 12:20 PM
cbgv2000's Avatar
cbgv2000
302 efi to carb
Got a 90 Eddie Bauer Bronco with 302 ho engine EFi.... Got into some trouble while i was 4wheeling and swamped it in 5 ft of water...... was thinging about rewiring it with a painless harness and then changing the engine to a carb set up...
Has anyone done or attempted this.... what all does the efi to carb entail and need for parts.....
or websites?
Old Sep 17, 2006 | 08:03 PM
84tealbeast's Avatar
84tealbeast
thats wut i would do, i would much rather pop my hood and perty much see spark plug wires and a battery like i do now
Old Sep 17, 2006 | 08:10 PM
dmc919's Avatar
dmc919
whats wrong with it now? you will be losing power and mpg by switching to carb, trust me i've done it and i wish i hadn't
Old Sep 18, 2006 | 07:21 AM
cbgv2000's Avatar
cbgv2000
Well....
Well..... i think the entire wiring harness is fried..... well noit the entire thing.... everything works except the engine... i pulled the computer and as soon as i get some money i will get a new one.... the engine turns over but will not start... no spark and ignition... i figured it might be cheaper to convert the engine over..... plus i can not find some of the relays anywhere
Old Sep 18, 2006 | 04:16 PM
dmanlyr's Avatar
dmanlyr
You should also consider that by switching to a carb that you wil be negativly affecting your off road performance if you are into hill climbing at all.
I have not seen water affect a harness in the way you are describing, at least not permantly. Have you removed all of the electrical plugs / connectors and cleaned / dried them? I have seen computers take a hike though from water so it is a good that you have one on its way.
David
