I have my 3-speed auxiliary installed and ready to roll. But I can't grease any of my brand-new U-joints because the tip of my grease gun won't fit between the knuckles! Does anyone know where I can get a smaller diameter tip? Is there one designed just for this operation? The only other option is to disconnect the flanges so I can open the angles wider...
[font size="1" color="#FF0000"]LAST EDITED ON 03-Jun-01 AT 03:15 PM (EST)[/font][p]Hi Charles, try going to a parts store or two for the grease gun tip, and take the old one with you to be sure you will find a smaller dia. tip. or, try 45 deg. zerk fittings maybe.
my 2.5 cents
p.s. i'd like to see some pics of yer ride sometime....
Wayne
e-mail
http://home.pacbell.net/whomrig
Charles, Have you tried rotating the shaft. Most are on angles and if you rotate it to the correct position you can grease it. I have found this to be true on my trucks, yours may be different.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Thanks for the tip (no pun intended). I found a slightly smaller tip, but I also had to rotate the joints to JUST the right angle. Then I could just barely get the gun tip on the fitting. What a RPITA though.
I'll take a few snaps of the aux. transmission setup soon. It's working great; RPM went from 3025 down to 2550 at 60 mph. Much quieter from the engine (although it's another set of gears whining...)
