Bronco II Ford Bronco II
2.8 Question
Old Sep 16, 2006 | 08:41 PM
bronco2454's Avatar
bronco2454
2.8 Question
I am wondering for everyone that has a 2.8 when they did their valve lash adjustment did it do a good job at making the motor sound more healthy. I am in the process of pulling mine to change all the gaskets and oil pump. Also will the changing of the valve stem seals make a difference. I really want to do this the right way but I don't have the money to pay for the machine work that is required to be able to rering and such. So I am hoping a simple gasket timing set and oil pump will hold it over for a while. The motor runs well but leaks oil.
Old Sep 17, 2006 | 12:41 AM
infoguy's Avatar
infoguy
valve lash
Yes, It does quiet the engine down noticably because they are solid lifters and the ajustment produces a much smoother power band and response. Worth the effort.
jetact
Mar 30, 2015 10:27 AM
RIKIL
Dec 7, 2011 01:33 PM
Canadianice
Bronco II
Mar 14, 2008 11:46 PM
ajstephan
1983 - 2012 Ranger & B-Series
Dec 17, 2003 11:53 AM
cryptonik420
Nov 12, 2003 06:50 AM
