Aerostar Ford Aerostar
Window probs.
Old Sep 16, 2006 | 08:35 PM
Web-Foot Freak's Avatar
Web-Foot Freak
Window probs.
My drivers window starting acting kinda odd... it goes down, and it doesn't come up. I unhooked the motor, and hooked up my test light (i fried my DVOM @ work). when I hit down, the light is bright. when i hit up, the light flickers. i tested every link I could think of, and every time the light was as bright as it could be. any ideas?
Old Sep 17, 2006 | 12:51 AM
xlt4wd90's Avatar
xlt4wd90
Web,
Someone on this forum had a similar problem recently. He traced it to a chaffed wire where it went from the door into the main cabin. This is the easiest thing to check first.
Old Sep 18, 2006 | 06:58 AM
Web-Foot Freak
i actually checked that... both the boot and all wires and looms that go thru the door jamb are intact
Old Sep 18, 2006 | 08:19 AM
mediaman67's Avatar
mediaman67
on my 89, it was the switch - same problem. Try soaking the contacts in Contact cleaner first, moving them back and forth... it worked for me for about a week, then the same problem... replaced the switch, and it was fine...
Your test light confirms that it's either like XL said, or a faulty switch...
if you move the switch slow with that test light on it, does it change? or is it the same? my guess is that you have a dead spot on the switch...
Hope any of this helps
GreenMachinee
20
Nov 28, 2014 05:02 PM
dclark46
Mar 23, 2013 04:19 PM
Brett At TheList
Apr 18, 2012 08:03 AM
CWO-06250
Feb 16, 2012 03:47 PM
nates78
Dec 18, 2010 10:49 PM
