Carb
Old Sep 15, 2006 | 06:24 PM
Redneck1465's Avatar
Redneck1465
Cool Carb
I have an 85 F150 with a 351 HO Winsor. It has the stock 4 barrel holley on it. My problem is that I rebuilt the carb and now im not sure how to dial the carb in because the truck seems to be running rich. I have also rebuilt the engine so I know that its the carb that is causing the truck to run rich. If anyone knows how to dial that carb in that would be great.
Old Sep 15, 2006 | 07:49 PM
8 Lugs's Avatar
8 Lugs
Is the choke wide open when the motor is warm?
Did you adjust the floats with the motor running as per the rebuild instructions?
Did you adjust the idle mixture screws after the truck warmed up, at idle with the choke plate wide open?
Are the secondary throttle plates shut tight?
Did you follow the rebuild instructions to the "T"?
Steve G.
Old Sep 15, 2006 | 08:24 PM
Forever Fords's Avatar
Forever Fords
Does that carb adjust through the front of the baseplate?
Old Sep 15, 2006 | 10:19 PM
Redneck1465
Angry Carb
The choke itself is working right and operating correctly. And I followed the rebuild instructions to the T. I also set the float levels while the engine was running per instructions. However the idle mixture is the problem. Im not really sure how to set them. I know where they are obviously but I have never set the idle mixture before. I am not sure what the right mixture would be. And it does adjust through the front of the baseplate.
Old Sep 15, 2006 | 10:39 PM
Forever Fords
Turn them in all the way but not tight...back them out 2 1/2 turns and adjust from there...a vac gauge would help to get it right!
Richard
Old Sep 15, 2006 | 11:02 PM
Redneck1465
So just play with them once you back them out the 2 1/2 turns?? Cause I believe that thats what I did when i rebuilt it was just run them in and then back them out 2 1/2 turns. And where would I place the vacuum gauge at??
Old Sep 15, 2006 | 11:58 PM
Forever Fords
Any port thats open on the carb or intake , try to get the highest vac reading possible and make sure you have no leaks!
Old Sep 16, 2006 | 12:04 AM
Bdox's Avatar
Bdox
Adjust one side at a time.
All you need to do is, from your initial setting, screw one in slowly until the engine just starts to stumble. Then back the screw out until the engine just smooths out.
Old Sep 17, 2006 | 12:20 AM
Redneck1465
Does anyone know what type of head the idle screws take??
Old Sep 17, 2006 | 12:48 AM
Forever Fords
I forget for sure but is it a small allen key?
Old Sep 21, 2006 | 09:11 PM
Forever Fords
Any update Redneck1465?
Old Sep 21, 2006 | 10:52 PM
Redneck1465
I am down at college right now so I think I am going to wait till I get back home for Thanksgiving before I attempt to dial it in. I just dont want to be stuck down in Bloomington if something for some reason goes wrong.
Old Oct 14, 2006 | 01:07 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
I'm having the same problem, but it tends to dissipate after warm up. I'm suspecting idle mix screws being calibrated wrong, but I'm not terribly sure.
We're working on an 84 bronco with the edelbrock 390 installed.
Like I said, the problem mostly goes away after warm up. When we start it, the engine gets flooded and stalls out. It gradually gets better, but the idle is never 'quite' right.
Ryan
Old Oct 17, 2006 | 04:12 AM
Redneck1465
Yeah thats pretty much the same thing that my truck does.
Old Oct 17, 2006 | 09:28 AM
Tom84150's Avatar
Tom84150
If it's the Holley 4180, there's two more idle mixture screws on the back--one for each secondary barrel.
-Tom
