Newbie needs help!
Old Sep 15, 2006 | 05:53 PM
guff's Avatar
guff
Newbie needs help!
I just bought a 2006 F 150 and absolutely love it. Unfortunately, with less than 4K miles on it, someone else with a similar height truck/van wiped out my mirror (drivers side), naturally, no number or note on my parked truck. The door was fine, the mirror smashed, the motor mount was broken off, so the parts guy ( a buddy of mine) said it would make sense to go for a whole new mirror assembly.
I ordered the whole assembly through the parts guy, it arrived today. Now I am trying to figure out how to get the panel off to get at the 3 screws that attach the mirror to the door. Has anyone sucessfully done this recently? I noticed there are 2 screws at the base of the door, and a pop-out panel which will probably yield a few more screws near the door handle.
Any help is appreciated!
Old Sep 16, 2006 | 05:44 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 16, 2006 | 06:19 AM
spiggy769's Avatar
spiggy769
Not including the screws you mentioned...there is One I believe under the armrest and I am assuming you have Power Windows...if you pop off the cover of the Power Window switches you will find one there also(You have to disconnect this anyway).
After that the Door just lifts up and out. GL.
Old Sep 16, 2006 | 07:29 AM
guff's Avatar
guff
thanks
Thanks, I'll give it a shot!
Old Sep 16, 2006 | 08:21 AM
jr105's Avatar
jr105
Do a search for "door panel removal" and you will get all the info you need. It's not hard to remove, but there is more to it than a couple of screws.
Old Sep 16, 2006 | 08:31 AM
dartguy699's Avatar
dartguy699
Wink
one thing to remember(critical) do not pry out on the panel--push up! the attaching pegs point down and will break off very easily if you do it wrong.
jim
Old Sep 16, 2006 | 10:37 AM
spiggy769's Avatar
spiggy769
Crap...Forgot aboutt he speaker...pry open the speaker cover and remove it. This has to come out also.
