Stalling when cold...
Old Sep 15, 2006 | 12:37 AM
Mr. Bob's Avatar
Mr. Bob
Hey Guys....
This is not my 6.9L, but a 1998 Cummins that belongs to a friend of mine...
It has aprox 70 000 miles on it, and in the morning, it starts fine, but if you hit the throttle, then let off it will stall.... It will always start fine, and will always re start fine too.... will stall right through till it worms up a bit...
I am thinking a possible glow plug issue, but would it start perfectly fine cold with bad glow plugs???
Sorry for the Dodge question, but Im a ford guy and have no desire to hunt through dodge forums...
thanks!!
Bob
Old Sep 15, 2006 | 08:40 PM
dwaymar's Avatar
dwaymar
if i'm not mistakin the cumins uses a heater in the intake system my 750 ford had this setup and all i did was change it out and worked good this was a wrecker so had to run and run
Old Sep 15, 2006 | 08:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
No glow plugs in a cummins, hair dryer element in the intake is where they get heat from.
Old Sep 16, 2006 | 01:54 AM
Mr. Bob's Avatar
Mr. Bob
Well you learn somthing new every day.... would that explain a stalling?? I quess it would huh???
